Gas Grades
Old Jan 8, 2010 | 02:07 PM
KCSKY7's Avatar
KCSKY7
Gas Grades
Pretty simple question, just curious to see what grade of gas people are useing in their G's. I just recently purchased a '08 G37S 6MT Black on Black Fully Loaded and I have been using middle grade.
What about you?
Old Jan 8, 2010 | 02:20 PM
Callaway's Avatar
Callaway
Arm flailing tube man
Premium only for me. This topic has been beaten to death btw.
Old Jan 8, 2010 | 02:26 PM
whiddles's Avatar
whiddles
^^^^ Same here 93 all the way. Sam please do not reply with 96,97,103 or what ever you have out there lol
Old Jan 8, 2010 | 02:28 PM
SnoopDawg's Avatar
SnoopDawg
I only use 93 and am trying to, as much as I can, stay away ethanol blends, but it's getting harder to find stations to do that.
Old Jan 8, 2010 | 02:30 PM
dt22cc's Avatar
dt22cc
You should be using premium 91 aki or greater. I believe your manual says something about it as well.
whiddles's Avatar
whiddles
only only buy shell. its been a good source for me.
Blackjack's Avatar
Blackjack
Premium here as well.
Old Jan 8, 2010 | 02:33 PM
g37mobbber's Avatar
g37mobbber
premium for me as well the higher the better!
Old Jan 8, 2010 | 02:48 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I ONLY ONLY ONLY use 93 (91 is the highest in some places). the manual says 91 or higher.
IF you are in a high altitude area (like Colorado) then using mid-grade is "acceptable" but I still use the highest octane I can find when I'm back in CO.
Old Jan 8, 2010 | 05:11 PM
fmrlegend's Avatar
fmrlegend
on the loaner cars that i get from the dealer, the guy tells me just to put 87 wink wink. I'm like "alright"
but it sucks for those who buys these "dealer certified" used cars later on.
Old Jan 8, 2010 | 10:01 PM
Arvig's Avatar
Arvig
As best as I can find at the local pump. All the places near me are only 91 octane, 10 percent ethanol blended in. If I knew of one that wasn't too far that had 93 octane and/or no ethanol I'd go there.
Old Jan 8, 2010 | 10:20 PM
G37Sam's Avatar
G37Sam
98 bro
Haha it is equivalent to the 93 you guys get in the US, just measured with a different stick.
Old Jan 8, 2010 | 10:32 PM
Chekov's Avatar
Chekov
Senior Citizen
Is the month up-- when we’re due for one of our regular threads, this time on the “What octane to use” debate?
Old Jan 8, 2010 | 11:16 PM
MechE's Avatar
MechE
Why is it that premium is required if the compression ratio is only 11:1? (Just a question. Don't get all crazy on me)Other, lesser cars have the same ratio but can run on regular. Isn't octane rating just the resistance that the blend has to early detonation (knock) brought on by high compression ratios. For example, some Hondas run at 14:1 and require premium.
Old Jan 8, 2010 | 11:28 PM
JohnEnglish's Avatar
JohnEnglish
I run what the manual says which is premium.
There are a lot of factors that influence octane rating, cam profiles, combustion chamber design, timing, etc. All these thing influence the actual combustion of the air/fuel mixture and how the pressure of ignition is handled.
