How often do you use ds-sport mode?
Old 11-25-2008, 01:06 AM
  #31
Baroker
Baroker's Avatar
So you just put your stick to the left and drive it? You dont have to shift or anything ?
Old 11-25-2008, 01:25 AM
  #32
shumby
shumby's Avatar
you can shift if you want to with the paddles or shifter but if not it will shift at red line and down shift more aggressively.
Old 11-25-2008, 05:21 AM
  #33
AussieV36
AussieV36's Avatar
I drive with the manual mode most of the time, my first auto so me still adjusting to an auto tranny lol
For the guys with grounding kits do these make a noticeable difference to paddle shift mode?
Old 11-25-2008, 09:10 AM
  #34
Heat
Heat's Avatar
Originally Posted by w0ady
i drove 95% of 68k miles in manumatic on my 35 with no issues to the transmission.
good info, have you tried other rpm's? i was thinking about starting with 2000 and going up not down actually.
On the track, No, only because you have to do it very quick after you stage, and I don't want to accidently over do it. Even at that 1500 rpm, the car wants to go, so you have to keep the brake tight. I keep wanting to try a higher rpm.
Old 11-25-2008, 09:14 AM
  #35
Heat
Heat's Avatar
I am 95% sure that it doesnt shift at redline. It shifts at the correct shift point for max powerband. I havent dyno'd mine yet so I am not sure what that number is, but I am guessing it is around 6200. When you hit the red line, it will bog down because of the rev limiter. Actually did it this past weekend by accident. oops....
Old 11-25-2008, 09:17 AM
  #36
shumby
shumby's Avatar
nope wrong it shifts just befor redline in DS
Old 11-25-2008, 09:24 AM
  #37
Heat
Heat's Avatar
I will have to check it out next time I drive it.
Old 11-25-2008, 09:26 AM
  #38
shumby
shumby's Avatar
ya i would reconfirm for ya but mine is crashed and I am waiting on the 09 hopefully this week. If your to the floor it will shift just before red line if you somewhere inbetween it will shift lower.
Old 11-25-2008, 09:27 AM
  #39
shumby
shumby's Avatar
Just realized that sounded a bit rude sorry was not ment that way. it is early here and i am tired. Thanks for not taking it the wrong way.
Old 11-25-2008, 09:29 AM
  #40
dagobah2003
dagobah2003's Avatar
Never, but love the fact that I have the option.
Old 11-25-2008, 09:39 AM
  #41
Heat
Heat's Avatar
This makes sense. I rarely ever floor it while in DS mode. Not unless I am really pissed off or I am at the track.
Old 11-25-2008, 02:48 PM
  #42
Baroker
Baroker's Avatar
ok so leaving it on ds mode wont hurht your car in any way right? Whats the pros of doing this too?
Old 11-25-2008, 02:51 PM
  #43
soldier9599
soldier9599's Avatar
My 6MT is in sport mode 24/7
Old 11-25-2008, 03:23 PM
  #44
w0ady
w0ady's Avatar
ya im pretty sure its redline. at least from what ive read/been told.
4 ways to drive an auto:
- leave it in D
- leave it in D and use paddle shifters
- pull it over for DS
- pull it over and use manumatic
as far as pros of DS, it shifts at redline so you get the most power obviously. of course, its a more aggressive way of driving so you have to be used to it. also, i believe the downshifts are more aggressive.
Old 11-25-2008, 05:19 PM
  #45
Heat
Heat's Avatar
5 ways, you can also put it in DS mode and use paddle shifters.'
The only con of driving in DS mode all the time is that you use a little extra gas. Just guessing that it will prob drop your mpg by 2-5 miles on average depending on your driving habits.
Quick Reply: How often do you use ds-sport mode?
