200K Mi trans fluid change
Recently just bought a cheap 180K G37 Sedan/Auto Trans and as i am now 200+K with it, I fail to check when the last service for the Trans fluid was. Is it safe to change it? or would it totally poop on me? TIA
If the last service was done by a dealer, your local dealership should be able to bring up the date and type of service done in your G's history. At 180K, a tranny flush with fresh ATF is a must. How does the 7-speed tranny operate currently?
Originally Posted by dkmura
(Post 4284148)
Originally Posted by hiddensalami
(Post 4284150)
Flushing the trans fluid at that mileage would destroy it no? Assuming it hasn’t been changed or flushed regularly before. Maybe a drain and refill but again, if it’s never been done before... it’s a risk
Do not touch it unless you have paper work it was changed every 30k miles from new
