I'm an idiot, help me out (6MT Clutch Issues)
:banghead: I did something stupid.
SO. Long story short. Bought a South Bend Stage 3 Daily Clutch. Didn't replace any bearings. Throw Out Bearing bound up, and burned my clutch really, really badly. So, my friends, what all do I need to buy/replace to keep this from happening again? And, does anyone by chance know how much JUST a replacement clutch disc is?.. :crying: |
I own an automatic but I did some research for you and came up with a couple good sites. I hope they're able to help you out...
Browse SPEC Clutch Infiniti G37 Clutch Disks https://m.reddit.com/r/infiniti/comm..._shock_i_need/ http://www.autopartswarehouse.com/sh...tml?redirect=1 Clutch Replacement Cost for Infiniti G37 - RepairPal Estimate I hope you're able to get it all solved without anymore issues. Keep us posted on the outcome and best of luck man. |
Wow, sorry for that man. That's an expensive mistake.
You need an HD CSC from ZSpeed and a new clutch disc. Replace the roller bearing and the master if you didn't last time. Inspect the flywheel for visible damage and pray it isn't messed up. |
Originally Posted by Thirty_Seven
(Post 4003844)
always replace the MC and CSC together.
(Post 4003829)
If you installed the HD CSC and the throw out bearing bound up then something is very wrong. They're not 2 separate parts like on most cars. Was the CSC purchased new?
(Post 4004028)
But still - do not know if this was a CSC issue, or an actual clutch issue. Whatever it is, the clutch doesn't even have 5k miles on it. So I'm pretty upset. |
| All times are GMT -4. The time now is 04:36 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
