Replacing Throttle Bodies
Hey everyone,
After numerous tries to clean thr throttle bodies, I have concluded the best thing now is to replace both throttle bodies. It doesn't seem to hard to replace, essentially the same steps as cleaning except you unplug the hoses and connector. My question revolves around the ECU. I know I will have to reset it with the pedal dance and perform the idle relearn as well. Is there anything else I have to do or is that it? Will I have to get some ECU upgrade or something? I have an 08 S 6MT. Thanks all |
my review on my "aftermarket" TBs would explain everything you need to know.
https://www.myg37.com/forums/engine-...le-bodies.html |
