How To: Dash Removal
I decided to remove my dash and have it upholstered with marine vinyl because it was cracking. I had some directions, but not all the descriptions had photos. I tried to supplement those steps with photos of my own to aid others in removal because some of the instructions in the drawings require many smaller steps not explained or pictured.
The descriptions in the drawing photos are located below the respective drawing. Remember this because sometimes the description is on the following drawing screenshot and may require scrolling down. Likewise any of my photos have the description below them, too. I strongly recommend you review and read each step in this post, completely, before undertaking this project. Removal took me 3.5hrs. https://cimg6.ibsrv.net/gimg/www.myg...7aa1ed1ef1.jpg Tools I used: various pry tools, 10mm, 12mm, 19mm, Torx 30 Security (you cannot complete removal without this) https://cimg7.ibsrv.net/gimg/www.myg...c09b826db.jpeg Overview doesnt include driver's wheel, which will need to be removed too. That removal is covered in this post. https://cimg8.ibsrv.net/gimg/www.myg...4085b291b.jpeg https://cimg0.ibsrv.net/gimg/www.myg...16cbb0d22.jpeg https://cimg1.ibsrv.net/gimg/www.myg...482ac2c91.jpeg https://cimg6.ibsrv.net/gimg/www.myg...19c901d93.jpeg https://cimg7.ibsrv.net/gimg/www.myg...04807f23a.jpeg https://cimg5.ibsrv.net/gimg/www.myg...9e0b4d0cc.jpeg https://cimg0.ibsrv.net/gimg/www.myg...ef624d2f8.jpeg view after removal of radio face and cluster lid https://cimg5.ibsrv.net/gimg/www.myg...4f7685d0a0.jpg https://cimg5.ibsrv.net/gimg/www.myg...b37d14683.jpeg https://cimg6.ibsrv.net/gimg/www.myg...64403c24ac.jpg https://cimg0.ibsrv.net/gimg/www.myg...bc83c5ec4.jpeg https://cimg1.ibsrv.net/gimg/www.myg...32c8381393.jpg https://cimg1.ibsrv.net/gimg/www.myg...d79a70769.jpeg https://cimg4.ibsrv.net/gimg/www.myg...41bcd972b.jpeg https://cimg7.ibsrv.net/gimg/www.myg...0693ea542c.jpg https://cimg8.ibsrv.net/gimg/www.myg...0768e3421a.jpg https://cimg2.ibsrv.net/gimg/www.myg...235f4e798b.jpg Torx 30 security bits covered by plastic covers. these remove the airbag which then slides straight out. https://cimg3.ibsrv.net/gimg/www.myg...047469439b.jpg after removal of air bag https://cimg4.ibsrv.net/gimg/www.myg...d21e7ebf1c.jpg remove 19MM nut. wheel slides straight off. then remove phillips heads on either side of steering column. they are covered with plastic caps (not shown) https://cimg9.ibsrv.net/gimg/www.myg...2bb2a3706.jpeg https://cimg1.ibsrv.net/gimg/www.myg...a4983f957.jpeg step 35 (as described in the next drawing photo) was difficult to remove the entire harness cover as instructed. the entire cover is supposed to be removed in order to gain access the four bolts that hold down the gauge cluster. However, after removing just the lid/cover of the harness cover and not the entire harness cover, i was able to access the 4 bolts (hopefully that makes sense). see photos directly below to aid with my poor explanation. https://cimg7.ibsrv.net/gimg/www.myg...4a4de51ff0.jpg https://cimg1.ibsrv.net/gimg/www.myg...0fe3fdcb88.jpg https://cimg3.ibsrv.net/gimg/www.myg...8795240b68.jpg https://cimg5.ibsrv.net/gimg/www.myg...fa78c63ed6.jpg https://cimg3.ibsrv.net/gimg/www.myg...1e38c041b.jpeg https://cimg6.ibsrv.net/gimg/www.myg...4483173f5e.jpg unplug these two clips to finish removal of the gauge cluster https://cimg5.ibsrv.net/gimg/www.myg...627a6bc524.jpg after removal of gauge cluster https://cimg3.ibsrv.net/gimg/www.myg...2e6caf7c9.jpeg https://cimg6.ibsrv.net/gimg/www.myg...ae24a54280.jpg https://cimg7.ibsrv.net/gimg/www.myg...027c50cbd5.jpg now move to the passenger side https://cimg0.ibsrv.net/gimg/www.myg...6bcb506454.jpg https://cimg4.ibsrv.net/gimg/www.myg...79cb34eca.jpeg https://cimg1.ibsrv.net/gimg/www.myg...72298dffdf.jpg https://cimg6.ibsrv.net/gimg/www.myg...0acc0545c.jpeg https://cimg7.ibsrv.net/gimg/www.myg...489dc94e5.jpeg https://cimg8.ibsrv.net/gimg/www.myg...fb7fb6afa.jpeg https://cimg8.ibsrv.net/gimg/www.myg...8d5b120af7.jpg defrost vents just pop out with pry tool along the front https://cimg0.ibsrv.net/gimg/www.myg...dd67800129.jpg https://cimg1.ibsrv.net/gimg/www.myg...4a3c081ec9.jpg be sure to unclip sensors, one in each vent. https://cimg9.ibsrv.net/gimg/www.myg...22b8285254.jpg Step 46 (big yellow airbag plug) and Step 47 10MM bolt as described in drawing below. https://cimg9.ibsrv.net/gimg/www.myg...5a0ef59f0.jpeg This drawing doesnt show the screw on the left side of the gauge cluster opening (it only shows the one on the right, so get both; they are obvious). The drawing also only shows one screw down low on the left (theres actually a screw and a bolt - see noted photo below) https://cimg7.ibsrv.net/gimg/www.myg...9fa8e64277.jpg second unlisted bolt, low and on the left dash should slide out, just be sure to disconnect the wire clips in driver's A pillar. https://cimg1.ibsrv.net/gimg/www.myg...d19c584343.jpg wire is clipped into metal A pillar. remove tabs from A pillar so the wire can go with the dash. https://cimg1.ibsrv.net/gimg/www.myg...2977d216a4.jpg pop out speaker grill from fronthttps://cimg3.ibsrv.net/gimg/www.myg...dce94fa6e0.jpg dash totally removed Hopefully you are able to follow this. Good luck. |
Thanks for posting this it definitely deserves sticky status. I know a lot of people will appreciate it especially those with the cracking/sticky dashboards
Fantastic write-up. Thank you for taking the time to tackle a project of this magnitude.
In researching how to do this I came across this video:
https://cimg9.ibsrv.net/gimg/www.myg...ae5aa45dbe.jpg
"after". I didn't have a "before" but I think we all know what a ****ty, cracking dash looks like. And the best part? No leftover parts! The labor AND material to recover the dash was $250, plus ~6hr of my time. Well worth it. |
Wow, That looks great! Has to be rewarding to see it turn out that clean when it's all done.
Great write up. I did this a few months ago myself. One thing to keep in mind is after you pop off the defrost vents, there are some plastic fasteners that hold the dash to the frame. Those are really hard to access and pop off. Just be patient with them, and gently use a smaller flathead screwdriver to work them up and out slowly. Once you pull the vents you can look through the front window to see them.
@handleandrew , you mentioned that you used marine-grade upholstery to recover your dash. Would you care to elaborate a little more on the material (ie. source, type, amount used, etc.)?
As I, inevitably, will have to tackle this project in the next few years- should I or the car be around- my only concern with covering the dash with vinyl/upholstery is how it may interfere with the passenger airbag deployment. Still, thank you for a excellent write up! |
Originally Posted by dmg6768
(Post 4246043)
(Post 4246044)
As I, inevitably, will have to tackle this project in the next few years- should I or the car be around- my only concern with covering the dash with vinyl/upholstery is how it may interfere with the passenger airbag deployment. Still, thank you for a excellent write up! Asfor airbags, those things come out at 300+ mph it's going to either tear through the vinyl or detach it from the edge of the dash. |
[QUOTE=handleandrew;4246016]https://cimg9.ibsrv.net/gimg/www.myg...ae5aa45dbe.jpg
I think something like this can be done inside car without removing dash, that color seems to be very close. Like a satin black |
Originally Posted by handleandrew
(Post 4246016)
Thank you for for this guide! I just got done replacing the dash in my 2010 coupe. It was extremely rough and looks great now (found a perfect condition dash from a local scrapyard).
I think the way to go is using the guide in this post, a printed version of the service manual, as well as this video I used for assistance on the gauge cluster: |
That's genius I'm really impressed.
most impressive, took me basically all day just to remove.. not a task for a newbie
