Poorboy's Spray and Gloss
Old Jun 22, 2010 | 10:31 PM
Steveo47's Avatar
Steveo47
So i recently did a full detail on my car. Swirl correction with Dodo Juice Lime, i used some Chemical Guys non-stick super slick gloss magnifier, followed up by two coats of Klasse Sealant Glaze and once coat of Dodo Juice Blue Velvet and one coat of Dodo Juice Purple Haze.
NOW the reason i tell you all this is because im using Poorboy's spray and gloss and am getting a cloudy haze all over my car, basically ruining all my work. Whats going on? are the products im using have a unforeseen reaction? An input would be great.
In addition i dont notice the hazing immediately after application, maybe a few hours after it appears.
Old Jun 22, 2010 | 11:11 PM
Jamler's Avatar
Jamler
I've used Poorboys spray/gloss with no issues... In fact I've used
just about everything from them from SSR1 through Black Hole... Love it.
Your situation is a Chem reaction to all the many different products you used.
It takes some time for cleaners, polishes and waxes to cure and likely
that is what your seeing... Let it be for a while and then give it a good wash
and dry then try the spray gloss in a small area to see if clouding happens.
Old Jun 23, 2010 | 12:17 AM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
Either you're spraying too much, or you are not turning over your towel. After the intial spray, you have to continue rubbing until you see it shine. I have Poorboys products and they work just fine, remember a little goes a long way.
Old Jun 23, 2010 | 01:24 AM
VRG37S's Avatar
VRG37S
Man thats a bunch of different steps you did.. How long did that take you?
Old Jun 23, 2010 | 02:24 PM
ucla bruin's Avatar
ucla bruin
How much time did you give each layer to cure before applying additional ones?
__________________
Old Jun 23, 2010 | 11:37 PM
Steveo47's Avatar
Steveo47
well the dodo juice and the chemical guys i gave no time.. since i figured they are both polishes. each coat of sealant and wax i gave 24 hours. It took me 3-4 days working maybe 2-3 hours a day?
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
Dillybar12
Nov 1, 2015 07:23 PM
faze2988
Oct 7, 2015 12:05 AM
Allboutcali
Sep 26, 2015 03:43 PM
