R3diK3r0u5's G
7 Attachment(s)
aka Raichyl
https://sphotos-b.xx.fbcdn.net/hphot...89831625_o.jpg https://farm8.staticflickr.com/7005/...efd04c1f_b.jpg This thread is just a place for me to keep track of the progression of my vehicle. All questions and criticisms are welcome! Mod List: -Passport 8500 w/ Invisicord & Mike's Mount -iPhone ProClip w/ custom wire running -Full de-badge -Input/video lockout bypass -Custom bass level control mounted inside ashtray -Alpine SWR-1242D powered by Alpine MRP-M500 w/ custom built box firing forward through rear seat pass-thru -Eibach Pro-Kit Springs [@45k] -Ark Performance Grip CBE [@48k] -DIY Bumper Plugs -BlackBetty Grounding Kit -R2C MaxxFlow [@57k] -Manual Hide Away license plate bracket -Vertini Magic Concave [custom gloss black finish] --20x9 +23 --20x10 +35 -'09 Sport Lip [@60k] -DIY Midnight Grille -White Turn Signals -Blue interior LEDs -Fast Intentions RHFC -DIY Gloss Black Headlights -6k Headlight Bulbs -6k Parking Lights -6k 35w 9006 HID Fog Kit Well I started with a 2007 G35s Sedan Garnet Ember/Graphite fully loaded w/ NAV & Bose. https://farm6.static.flickr.com/5164...9756d5f109.jpg First Mod was to find a cleaner solution for my radar detector. Ordered the Invisicord so I could hook up to my mirror to lose the power cord across my dash and Mike's Mount to get rid of the suction cups so that my sun reflector could be put up behind the detector and save it from the sun. https://farm5.static.flickr.com/4103...4e92d9b264.jpg My only complaint here is that the piece of the original mount you use along with Mike's Mount is too thin to properly rest in the Passport. This causes rattling. I just shoved a plastic wedge in the back to make it secure and haven't had any problems. I later found Blendmount.com - Custom Radar Detector Mounts* Escort Beltronics Valentine One which looks to be a much nicer mount and solves the rattling problem with a spring loaded clip. But my mount is working out fine and was $60 cheaper. Next, I needed a solution for my iPhone. I charge it in my car and use it for music and videos. https://farm5.static.flickr.com/4103...2ababeb1e8.jpg I found the ProClip to be a really clean mount that looks like it came from the dealership this way. Happy with its location and quality. I have drilled a hole just behind the mount and in the console to run the wires [power and AV] inside the console instead of outside. No more cord getting in the way when I try to shut my console! Zhao, a friend on strictlygs.com, then started selling LED's so I went ahead and did those. All interior and exterior. https://farm5.static.flickr.com/4127...ea10cbb091.jpg https://farm5.static.flickr.com/4151...b8018c9a0f.jpg https://farm6.static.flickr.com/5170...aed7c08229.jpg I took the picture of the parking light that way to show the stress cracks that have formed on my headlights. Already failed once at getting it replaced under warranty, will be trying a new dealership next maintenance. *1/12/11 Had them replaced* De-badged my trunk. Only removed the "G35s" lettering. Still considering removing the "Infiniti" lettering from under the Mt. Fuji symbol, but I like the way it keeps things centered. Also considering just taking it all off, just can't make up my mind. http://i1086.photobucket.com/albums/...2/IMG_0227.jpg I have since then fully de-badged it. [Pic MIA] Next I finally did the input/video lockout bypass. Located the VSS switch in the console just above the AV inputs. https://farm5.static.flickr.com/4124...0085edc481.jpg I have a hole drilled just under the AV cables to run the wires inside the console to the iPhone mounted by the shifter. If you look closely you can see how I messed up. I was in a hurry and slipped with my drill bit and ate away some of the felt between the 12v and AV :Grimmace: While I had the dash apart doing that previous project, I decided to wire up my bass level control knob and hide it in the ashtray. https://farm5.static.flickr.com/4126...cb1cf9631e.jpg I love how hidden it can be but at times is a little annoying to access. It's fine and not a problem when the shifter is in Drive, but is cramped when in Park. Next I installed my Alpine SWR-1242D powered by an Alpine MRP-M500 in a custom built box firing forward through rear seat pass-thru that I fabricated myself. It seals up flush against the back seat. This was my first time to wire a vehicle and my first box to ever build. Wow was I happy when everything came together and it actually all worked :D https://farm6.static.flickr.com/5161...eab349292b.jpg https://farm5.static.flickr.com/4133...243e46b349.jpg https://farm5.static.flickr.com/4113...f134fd8087.jpg I removed the plastic door between the armrest and the pass-thru to keep it from rattling. Time for the drop! picked em up used for $120 https://farm5.static.flickr.com/4127...3585bc07df.jpg Working hard! https://farm6.static.flickr.com/5126...9ae6f29065.jpg Finally taking my victory lap https://farm6.static.flickr.com/5242...90797b43ab.jpg Thanks to all the members of strictlygs.com who came out to the meet and lent their hands and knowledge! Headlights, door pulls, and steering wheel fixed! [Pic MIA] Had them all replaced for free under warranty. In the process they lost my 6000k parking lights but they put in 6000k headlamps for me! Sounds like I won in that trade! Ark Performance Grip CBE was next! https://farm6.static.flickr.com/5125...9aed4bc514.jpg https://farm6.static.flickr.com/5284...c83bf805ca.jpg Stock Sound Clip DIY Bumper Plugs Just bought some plugs from home depot and painted them with the correct touch up paint. Bored the holes out to the right size for the plugs. http://i1086.photobucket.com/albums/...2/IMG_0228.jpg Attachment 176445 BlackBetty Grounding Kit Attachment 176446 I routed the wires a little different than the instructions and I think it all came out great. Attachment 176447 Full Paint Correction with the PC Before Attachment 176448 After Attachment 176449 R2C MaxxFlow! [Pic MIA] For audio comparison, I took a video of the stock intake and R2C in park but they sounded almost identical. The growl really comes in while the car is under load. Really starts to get loud around 4.5k. When I get on it, I can't even hear my exhaust anymore. Here is a quick and cruddy video my friend took while we were driving so you can hear it under load. I also added a Hide Away license plate bracket. Although I liked the fun-ness of the powered one, I went the economical route and bought the manual one. I cut out a section of the black mesh in order to have a place to mount it in the middle of the bumper instead on the bottom. I finally found my wheels! Vertini Magic Concave 20x9 +23 20x10 +35 wrapped with 245/35/20 275/30/20 http://farm7.static.flickr.com/6159/...93f576c5_b.jpg http://i1086.photobucket.com/albums/...n/IMG_0827.jpg Attachment 176450 Attachment 176451 [1/17/12] [60k] Sport Lip! http://www.flickr.com/photos/74520361@N03/6722772667/Pretty easy to install with the included template. Everything lined up great except the middle two holes were way off so I have a few extra holes under my bumper.. -DIY Midnight Grille Taped off the areas I wanted to remain chrome and roughed up the middle section I was painting with some sandpaper https://farm9.staticflickr.com/8019/...e8b0d4cb_c.jpg Painted a few coats of color and a few coats of clear https://farm8.staticflickr.com/7132/...1d6a6353_c.jpg Installed https://farm9.staticflickr.com/8022/...8c42e677_c.jpg *This post is at maximum length and now continues on page 3 post #39* Thanks for checking it out and leaving your input! Jd |
love the wheels. maybe a black grill will compliment it nicely.
So sick!!! love the wheels! Glad they came out great!
We need a pro shoot on that thing ASAP! |
Nice car, red is a good color
red is the way to go! I just wish your rim didnt have the chrome lip, always love the all black (as i have on mine) I also debadge but left the mt fuji symbol. Was thinking of doing the same for the sub, having it mounted to point in, how does it sound like that?
Nice work so far! Looking good. Any future mods?
Looks sick, JD! Can't wait to see it in person!
Sick wheels. Are you running any additional camber? Does it rub? Do you have a pic that shows how close to flush those offsets are?
also black out the chrome window trim. might set off the wheels nicely.
Grill and window trim should be blacked out but other than that it looks great.
Originally Posted by A_Palaroan
(Post 3248378)
What brand of cigarette lighter to USB did you use to get it to charge an iPhone 4
keep em going!
thanks for checking it out guys!
Originally Posted by sniper27
(Post 3247848)
Originally Posted by GetYourWheels
(Post 3247886)
Originally Posted by kaoticdemize
(Post 3247914)
Personally I think the sub this way and the things in my trunk dont have the chance of damaging it. It does sound much better with the armrest down and i ended up taking off the plastic door because it would rattle if the armrest was up
Originally Posted by OB G
(Post 3248076)
Originally Posted by rod_b
(Post 3248363)
(Post 3248416)
Originally Posted by kkokko
(Post 3248529)
cool do you have a DIY for the pro clip install?
Any reason why you chose that version instead of the other one that slides into the console bezel. |
| All times are GMT -4. The time now is 10:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
