Notices
How to connect LED exterior lights to battery and fuse?
Old 04-24-2017, 05:54 PM
taimysho0
taimysho0's Avatar
Hello
I just bought a set of LED strips to use as DRLs for my car. Basically it will turn on when ignition is turned on and turn off if headlight is turned on. I read the instructions and the negative wire goes to negative on battery and positive wire should plug to the ignition fuse?
I found the fuse but its part of a module with 2 other fuses (30A). How do i connect my wire (see pic) and connect to this module? Do i just pull off the plastic on the top of the fuse module? I just dont want to break anything...
Old 04-29-2017, 12:12 AM
JustROLLIN
JustROLLIN's Avatar
If you have room, you can tuck the wire around the prongs of the fuse and plug the fuse back into place. That being said, its not a big deal, you can tap into anything that uses the same circuit as the ignition for source voltage.
I am not a fan of using voltage at a fuse. Really, you should be tapping in somewhere downstream from the fuse, so if it pops, it will kill everything that could be harmed.
