Power locks and Windows not responding HELP!!!
Guys Help pls! From one night to another my car switches are not responding what's weird is the driver side window works fine every other one does not. The locks don't respond either . Can it b a fuse? Please any advise asap !!! :eek:
Can you lock/unlock with the remote? If you hold the unlock button down for several seconds, do the windows roll down?
So they do unlock with key remote but don't from button in the inside and when holding down the unlock button few seconds they Windows don't go down. But again they are responding to the lock from the remote at least
Mine did the exact same thing. Come to find out the window motor shorted out everything. Had them replaced twice. Coupe!!
You think is window motor? How much is one of those? How can I find out for sure
Guys update this is freakin weird so I did the remote test and it worked all
The Windows we t down and the power lock seems b responding now only problem now is after all window went down I was able put all them back up except for rear passenger it's the only one not responding and it's all The way down it so weird |
I had the same problem and I had to replace the master switch.
Is there anything I can do to get window back up? At least while I look
Into purchasing the part |
if neither the driver's door switch or the RR door switch works (be sure you don't have the window lock button engaged in driver's door) then try using the mechanical key; lock and hold in the lock position. That may close all the windows in the same way the FOB can open them all.
thanks guys well weirdly enough they all started working and again today went back out i had the dealership check it out and they couldn't find anything and told me most likely signs of the master switch going out. anyone know where i can get this part fro cheap or cheaper than dealership at least?
so now all windows working except the rear passenger only. now what happens is when i put it down it wont go back up right away have to hit switch couple times
I had the same problem with driver door window switch.
It toke me about 15 minutes to solve the problem Remove the switch (no need to remove the door finish) Disansemble the switch, remove the electronic PCB from the switch plastic case, clean the PCB using brake cleaner spray, let the PCB dry for 5 minutes, reassemble the switch and install it back into the door. Problem solved. PS. Do NOT let the brake cleaner get in contact with any plastic or rubber parts!!! |
Can the switch be removed by removing the panel on the drivers door and pulling out the switch?
1 Attachment(s)
Yes. You only need to pull out (up) the switch assembly.
No need to remove the entire door panel. Check the service manual for more details. |
Its easy follow th instruction and change that module.
