MyG37
MyG37 (https://www.myg37.com/forums/)
-   Body Interior Exterior Lighting (https://www.myg37.com/forums/body-interior-exterior-lighting-314/)
-   -   LED Fog Light Bulb won't fit on Passenger Side - 2011 G37xs Coupe (https://www.myg37.com/forums/body-interior-exterior-lighting/265043-led-fog-light-bulb-wont-fit-on-passenger-side-2011-g37xs-coupe.html)
adlee3 Feb 13, 2015 02:14 PM
I wanted to get LED's installed for my fog lights on my G37 Coupe. I ended up installing the bulb for the driver's side by myself, but couldn't do much when it came to the Passenger Side. I took it to a dealer to have the bulb installed on the Passenger side, but I was told and showed that the LED bulb wouldn't fit because of the Washer Fluid Reservoir Tank.
Below is the link of the fog light I was trying to install. It's the XML2 version. The one that looks different than the others. Was anyone able to successfully get these in? If so, how did you get it to fit?
2011-2013 Infiniti G37 Coupe Fog Light LEDs (pair) - G37 Coupe - Infiniti - Bulbs By Vehicle - Lighting
tite_tite Feb 16, 2015 07:01 PM
https://www.myg37.com/forums/body-in...ight-leds.html
TVPostSound Feb 17, 2015 03:30 PM
I doubt it will work at all, its hard enough to install the right side recommended bulbs.
dysons Feb 20, 2015 06:59 AM
LED Bulb Install
What's up adlee3,
I have a 2011 IPL and I had the same problem. There are two screws on the back of the fog lamp housing mounted east and west that you have to remove then once you have removed the housing, mount the bulb then set the whole assembly back in place. Give this a try and it should work.
© 2026 MH Sub I, LLC dba Internet Brands
