Help Please! Tail light problem when braking.
I own a g37s and I recently found out that my tail lights along with my third braking light, don't light up when I'm braking. I don't think the tail lights themselves are broken because at night when I lock the car with the fob they light up fine. I have no idea what is wrong and I'm afraid that I might get rear ended if I brake too fast, and the car behind is not alerted. Is there any way someone may assist me in resolving this? thanks :)
Wiring iss messed up....
It could have gotten unplugged.
My process to fix things like this goes something like:
1) Drive car to dealer. 2) Tell dealer to fix it. 3) Profit. Edit: Unless you were ****ing around with something back there, in which case you better cover it up first. It worked for my ECU so I don't see why something like this would be a problem. |
Sounds like the brake switch on the pedal to me.
blown fuse maybe?
Troubleshoot starting with easy first...like the fuse!
