Window won't go back up
Old Nov 25, 2016 | 06:53 PM
GariepyVQ's Avatar
GariepyVQ
When I open the door and the window goes down like a cm, it doesn't go up again when I close it. Just changed my spark plugs so my negative terminal was disconnected for a while, haven't touched anything else electrical. But once I buttoned everything back up the window won't go back up when I close the door. Still works via door controls. Tried an ecu reset and still nothing. Any ideas?
Old Nov 25, 2016 | 06:59 PM
GariepyVQ's Avatar
GariepyVQ
Noticed that it's on both sides, plus my license plate lights won't turn on anymore.
Old Nov 25, 2016 | 07:02 PM
Whitevanman's Avatar
Whitevanman
Have you tried sending window down and then up again and keep the switch in the up position for about 5 seconds?
Old Nov 25, 2016 | 07:08 PM
GariepyVQ's Avatar
GariepyVQ
Just tried it and seemed to fix it thanks, any ideas about the license plate light?
Old Nov 25, 2016 | 07:21 PM
Whitevanman
Not sure about that, start with basics check bulbs and fuses..........
I had the same problem with my windows after swapping battery out........
