iPhone connectivity issues
Old 11-15-2017, 12:27 AM
  #46
Rothy11
Rothy11's Avatar
Originally Posted by Crazyirish
The later Gs dont have an aux port.
could u please describe later. I have a 2012 Sedan. Would this help my connectivity problem TIA
Cwickenstein (11-27-2017)
Old 11-15-2017, 01:25 AM
  #47
Crazyirish
Crazyirish's Avatar
2010 and later IIRC only have a usb port. No 3.5mm stereo jack or RCA inputs.
Old 11-15-2017, 04:39 AM
  #48
Awakence
Awakence's Avatar
Updated to the new IOS and my Bluetooth keeps on disconnecting. The screen is telling me that the phone is not compatible when i disconnect. Found that turning the Bluetooth off then on fixes the problem temporary. This got too annoying so i just use the usb plug usually now.
Old 11-17-2017, 09:37 PM
  #49
enigmacarpc
enigmacarpc's Avatar
So in IOS 10 many of us had issues with calls coming in and we could hear the caller but they couldn't hear us, now with IOS 11 I get:
1.Long Bluetooth connect times
2. Regular disconnects of Bluetooth
3. Choppy music streaming through Bluetooth of internet-based apps and locally stored iTunes music.
Fixes so far:
1. Go to Bluetooth settings and manually click connect on the cars Bluetooth and the phone connects but won't do it automatically.
2.Restart phone to fix disconnect or power off and on again or turn Bluetooth off and on again.
3. Play Music from USB avoid using Bluetooth for music.
I have used an iPhone 8 got choppy music and disconnects.
Iphone 6 Plus with fresh IOS install and without both get connection issues with Bluetooth but no choppy music.
Seems our horrible Bluetooth in our cars will always have issues before all the disconnects it was the bad microphone that always makes people think I have a bad phone signal.
Old 11-18-2017, 08:02 AM
  #50
Landshark
Landshark's Avatar
i have an older iPhone with no cell service that i just leave in the car (connected to USB) for music.
after IOS10, the car doesn't "see" it every 3rd or 4th time i start the car, and have to unplug it and plug it back in. very annoying.
never had that problem before i updated. will not update it any further.
Old 11-19-2017, 01:25 PM
  #51
telcoman
telcoman's Avatar
Originally Posted by telcoman
IOS 10.3.2 is the latest version
Telcoman
IOS 11.1.2 is now the latest version
Old 11-20-2017, 11:02 AM
  #52
mdigiorgio35
mdigiorgio35's Avatar
Fixes so far:
As for #3, not sure if anyone has experienced this but my phone connects fine to play music BUT for some strange reason my escort picks up the signal the iphone emits and the "laser" signal is set off on my radar detector...WILD
Old 11-22-2017, 04:24 PM
  #53
Crazyirish
Crazyirish's Avatar
Picked up an LG V30 to replace the iPhone. Works perfect right out of the box.
Old 11-22-2017, 06:15 PM
  #54
Rothy11
Rothy11's Avatar
who should I be mad at for this problem Apple or Infiniti?
Old 11-24-2017, 02:29 PM
  #55
enigmacarpc
Both LOL
Old 11-27-2017, 05:45 PM
  #56
Cwickenstein
Cwickenstein's Avatar
Originally Posted by ersatz
I'm having the same issue since the newest iPhone updates. I've read that there is an update that can be applied by the dealer that will fix this.
https://discussions.apple.com/thread...art=0&tstart=0
Is there a fee for the dealer update? Will the update fix the Bluetooth Audio disconnect?
Thanks!
Old 11-27-2017, 05:55 PM
  #57
Cwickenstein
Fixes so far:
My iPhone 6 disconnects every hour or less (sometimes several times an hour) when streaming audio. RARELY does it restart playing music after it reconnects itself, which takes about 30+ seconds. Then, after reconnect and restart music, it cuts out about 15-30 seconds later, while audio track is still playing (track didn't stop, just no audio) and then continues playing audio after about 3 seconds.
My '13 Altima did the same thing, but not quite as often.
The USB connection refuses to connect to my iPhone. It starts to charge then disconnects and reconnects rapidly over and over. I'm afraid it will burn out the phone doing that, so I haven't used it. Is there a firmware/software update available to fix these issues?
Thanks for the thread!!!
Old 12-12-2017, 01:34 AM
  #58
codeflux
codeflux's Avatar
Same problems... iPhone 6S + 2011 G37 sedan with navi.
Bluetooth disconnects every 10 minutes +/- a few seconds. First started with iOS 9, then was somehow fixed with iOS 10, and now happening again with iOS 11.
Sometimes phone reconnects by itself, sometimes it doesn't at all. Sometimes power-cycling bluetooth on the car and/or on the phone works, sometimes it doesn't. Sometimes wheel controls stop working...
Extremely annoying, considering it's my only source of music/podcasts on my commute.
Cwickenstein (12-22-2017)
Old 12-22-2017, 03:04 PM
  #59
Cwickenstein
Sounds like we have the same model/trim/year with the same issues. Any technical advice or options out there?
Old 12-22-2017, 03:19 PM
  #60
telcoman
telcoman's Avatar
IOS 11.2.1 is now the latest version
Telcoman
