Best Replacement Tires for G37S?
thatsgr8 (04-21-2016)
#62
Best Tire is the H-Rated Continental - No Seriously
If you don't plan on driving the car to its speed limit, but only up to 130 MPH, then nothing beats the H-rated Continental. Oh, and not only does it outperform V and faster tires in the dry, wet, and around corners, it is quieter, gets better fuel economy, and lasts a lot longer (800 AA rated) Check it out: Continental*TrueContact
#63
If tires shops could legally install them, that would be great.
You have to take your wheels to a tire shop and have them dismount the old tires. Make a second trip with the bare wheels and new tires. They wouldn't know what car the wheels came from unless you blurt it out.
#67
You get more grip with wider tires... but make sure that your wheel size matches the tire size. If you have the OEM 19" sport wheels then I believe 275 is the widest allowed for the rear.
#68
The main thing is getting quality tires regardless of size. The wider tires will give a more planted feel and along w/ a bit more camber will provide better cornering grip. Like 93 mentioned, don't want to go wider than a 275 on that rear 9" width wheel, and TBH I'd go no wider than a 265 on that one.
#69
#73
conflicting advice and specs
Finally according to :Infiniti G 2013 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com, the oem rims are not 8.5 and 9, but rather 8 and 8.5? (unlike previously posted on this site as fact)
225/45ZR19 94W
245/40ZR19
8Jx19 ET45
8.5Jx19 ET50 5x114.3 M12 x 1.25 66.1 2.1
I just dont want to mess up something! someone help clear up the above. thanks.
#74
MYG37.COM Platinum Sponsor
The 275's are a fit we dont show for some reason. People have been using it for years with no problems. OEM G37 sport coupe wheels are 19x8.5 front and 19x9.0 rear, which can also be verified at transwheel.com. You can use the 285's, but if you're having issues and/or want a touch more conservative fit, the 275 works fine.
#75
and 45mm offset ending in part number 59u (4.5 inches b.p)
4.5 inches is 115mm but 2 different part numbers? How the heck do I know which is true oem?
