Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Today's Daily special (January 16, 2011) is Chemical Guys Grime Reaper A.P.C..
Regular Price for 16 oz is $8.99. Today's price is $6.47!
Regular Price for 128 oz is $26.99. Today's price is $20.46!
- One of our most powerful degreasers available, designed to easily cut through contamination
- Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
- Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
- Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Today's Daily special (January 17, 2011) is Chemical Guys Celeste Dettaglio Paste Wax.
Regular Price for 8 oz is $174.99. Today's price is $129.49!
- When your car demands a deep, wet, glossy finish, that is easy to apply and remove look no further than Celeste
- Rivals results from other high end carnauba waxes that cost over 5x as much!
Today's Daily special (January 18, 2011) is Menzerna Super Intensive Polish PO83.
Regular Price for 32 oz is $44.99. Today's price is $32.39!
Regular Price for 16 oz is $29.99. Today's price is $21.29!
- Our best medium cutting polish that is known to remove moderate imperfections in the clear coat
- Most noted for its ability to cut well, good work time, easy removal process and great finish
- On lighter colored vehicles, it is not always necessary to follow up with a finer polish
- On darker colored vehicles, we recommend following up with a finer polish, such as PO106FF
- Most commonly applied with an orange light cutting pad when using a buffer
Today's Daily special (January 20, 2011) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $9.93!
- Perfect maintenance shampoo that enhances gloss and depth
- Lots of lubricity and slickness to help minimize adding imperfections
- Concentrated formula means only a little product is needed per wash
- Best used with a grout sponge or sheepskin wash mitt
Today's Daily special (January 21, 2011) is Chemical Guys Silk Shine Dressing & Protectant.
Regular Price for 16 oz is $8.99. Today's price is $6.56!
- Very versatile dressing that restores vinyl, rubber and tires to a beautiful low gloss finish
- Properly protect your vinyl and rubber surfaces from UV fading with CG Silk Shine Dressing
- To avoid over spray, we recommend misting Silk Shine Dressing into a microfiber towel to apply
- We recommend using a 4oz pump spray bottle to apply a thin, even layer of dressing
Today's Daily special (January 23, 2011) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.47!
- Perfect wash medium to help minimize adding swirls and other imperfections to the paint
- The natural fibers help pull contamination away from the surface without grinding them in
- When done using, rinse any contamination using free flowing water than hang dry with leather hoop
- For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Today's Daily special (January 25, 2011) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 5.5 inch is $8.99. Today's price is $6.65!
Regular Price for 4 inch is $4.99. Today's price is $3.69!
- Our softest foam pad, the blue fine finishing pad, designed to apply sealants and liquid waxes
- Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
- Jet Seal 109 is one of the most popular sealants to apply with a blue pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (January 27, 2011) is Menzerna PO106FA Nano Polish (Super Finish).
Regular Price for 16 oz is $26.99. Today's price is $20.73!
Regular Price for 32 oz is $49.99. Today's price is $38.19!
- Our best selling finishing polish that removes light imperfections and lots of depth and gloss
- Easy to work with, with long work times and easy removal when properly broken down
- Most commonly applied with a white polishing pad for a great combination of cut and gloss
- Can also be applied with a black or blue finishing pad for additional depth and gloss but less cut
Today's Daily special (January 28, 2011) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $8.99. Today's price is $6.70!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
- A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
- Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
Today's Daily special (January 31, 2011) is Chemical Guys Citrus Wash & Gloss.
Regular Price for 128 oz is $25.99. Today's price is $20.10!
- One of our best selling shampoos, lots of foam, great lubricity, strong cleaning power and versatile
- Can be used in high concentration to strip off previous coats of protection or diluted as a maintenance shampoo
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
- Works great in a foam gun, such as the Gilmour Foamaster II
Today's Daily special (February 1, 2011) is Lake Country 5" Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.40!
- Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
- Get optimal results with the 5.5" Lake Country foam and wool pads
- Allows you to easily put on new pads and pull of the old ones in just seconds
#29
Today's Daily special (February 6, 2011) is P21S Total Auto Wash.
Regular Price for 1000 ml Kit is $16.99. Today's price is $13.81!
Regular Price for 5000 ml is $64.99. Today's price is $46.14!
- One of the most versatile products we offer, degrease nearly any surface safely and effectively
- Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
- Can be used at full strength or diluted down to clean more delicate surfaces
- Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
- A must have any detailing enthusiasts or pro detailers arsenal of products
#30
Today's Daily special (February 8, 2011) is Lake Country Hydro Tech Tangerine Ultra Fine Polishing Pad.
Regular Price for 5.5 inch is $8.99. Today's price is $6.56!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
- Great polishing power with the ability to finish down haze and marring free
- Hydro Tech foam keeps more polish on the surface of the pad for long work time
- Experience less dusting than traditional foam pads due to less product buildup
- Save time and improve your results!
