DIY: G37 Automatic Transmission Fluid Change, Pan Drop/Clean
Old 10-12-2015, 10:07 PM
  #31
winner00
winner00's Avatar
Nice!
Got a pic or a link for that pan, and does it hold more ATF and/or has cooling fins?
Level 10 Deep Transmission Pan Nissan-Infiniti RE5R05A
blnewt (10-12-2015)
Old 03-17-2016, 03:54 PM
  #32
Snipres
Snipres's Avatar
Where is the refill plug located?
Old 03-17-2016, 04:54 PM
  #33
Snipres
Snipres's Avatar
Wow nvm infound it... In the picture the reflection off the black pan made it seem like you had a smaller tub off yhe fitting going somewhere
Old 03-27-2016, 10:15 PM
  #34
wquiles
wquiles's Avatar
Thank you guys for a great write-up
blnewt (03-28-2016)
Old 06-02-2016, 11:46 AM
  #35
Kris9884
Kris9884's Avatar
Great info! I'll be tackling the trans, diff and motor oil this weekend. Gonna be a real grease monkey by Monday lol
Old 07-08-2016, 08:30 AM
  #36
CPJ LB
CPJ LB's Avatar
awesome write up! I've been reading this thread and researching other forums (370Z) so I think I have a good idea on how to get this done. I went to the dealer in order to get an idea what they would charge for a drain/fill and got some surprising information.
Firstly, they indicated that they do not do the simple drain/fill. Instead, they prefer doing the power flush ($299). I said that it was strange for Infiniti to offer power flushes since I heard it was not recommended. I was told that ever dealer has different policies. LOL. I then asked, "how would one know if their transmission fluid is low?" and I was told that the tech would need to verify fluid levels by using the Consult tool. I then asked, "why does Infiniti indicate that the 7AT is non-serviceable when in fact it is?"
....crickets. Then I was told there is no trans oil filter which makes the transmission non-serviceable. I remained calm and was laughing inside since I know THERE IS a trans oil filter. It just reaffirmed my belief that the majority of the dealers/service advisors do not have a good understanding of what is/isn't available.
Next, after some going back and forth, I was informed that they will be able to 'top - off' transmission fluid if requested by the customer. I was informed that it would involve the tech's rate ($130) and approx $11 per quart - as needed. unbelievable.
Anyway, here's what I found since my dealer encounter:
1. A reputable transmission shop (I've contacted 3 in my area) can charge an average of $220 - $300 for the following: drain/drop trans pan, clean pan, refill trans fluid with compatible trans fluid to Matic S
2. Replacement Trans oil filter is available for the 7AT - I've attached the link to the catalog in which you will find the replacement for our 7AT (RE7R01A) ... just do a 'control F' on the pdf to bring up our specific trans part. The phone number to call is listed as: 800-568-0330
http://www.raybestospowertrain.com/%..._010516_re.pdf
I'm at 60K miles right now so I plan on dropping the trans pan in the near future to do the service (change fluid, clean pan, replace trans oil gasket).
Old 07-08-2016, 08:56 AM
  #37
Received 4,941 Likes on 4,174 Posts
Awesome find on the trans filter^^^
I searched high & low w/ no luck. Luckily my filter looked real good, no sludge buildup or noticeable deposits from what I could see.
Old 07-08-2016, 09:38 AM
  #38
CPJ LB
CPJ LB's Avatar
thank you kind sir! I appreciate you and the OP's DIY notation to this 'mystery' fluid change that Infiniti keeps from us...LOL. I'm old school, so I know that fluids do not last a lifetime. Plus changing fluids on a vehicle bought used is always something that I've done over the years.
BTW, I looked up Level 10 trans pan replacements and they only have it for the G35 (5AT). booo.
Old 07-08-2016, 10:12 PM
  #39
wquiles
wquiles's Avatar
Thanks to this thread, I did a partial fluid change this time (67K miles) sans the pan drop. Next time I plan on doing more. Good thing the original fluid came out beautiful - like new:
I measured how much came out so that I would add exactly the same amount back of the new fluid:
Easy and straight forward
The following 2 users liked this post by wquiles:
blnewt (07-08-2016), MStrike (10-10-2021)
Old 07-31-2016, 07:31 AM
  #40
dmill86
dmill86's Avatar
Hey guys, total noob here. Got a couple questions. With the 5AT, since it has a tranny dipstick, could I just refill from the dipstick instead of from the refill plug? thus eliminating the need for a oil transfer pump? also, what did you guys use to clean your pan? can it be sprayed down with brake cleaner? Thanks
Old 07-31-2016, 11:49 AM
  #41
Check the FSM for the 5AT, here's the link, click on TM.pdf and go to page 214 and start there.
Index of /FSM/G37/Coupe/2008
When I cleaned my pan just used some paper towels, it cleaned up real well, as did the magnets, then a final wipe down w/ a lint free cloth.
Old 07-31-2016, 04:49 PM
  #42
dmill86
dmill86's Avatar
thanks a lot blnewt. That link gave me all the info I need. Sorry if I posted in the wrong thread.
Old 07-31-2016, 05:58 PM
  #43
dmill86
dmill86's Avatar
Do you guys always replace your crush washers? ( drain plug gaskets) I've read that some do, some don't. Is it absolutely necessary? also, are the drain plug gaskets the same size for both oil drain plug and trans fluid drain plug. Thanks
Old 07-31-2016, 11:30 PM
  #44
I didn't change mine, and change my oil crush washers only a 2-3x in 80k miles, never had any leaks.
Old 08-01-2016, 07:44 AM
  #45
dmill86
dmill86's Avatar
ok thanks blnewt. Would you happen to know if the crush washers are the same size for both the oil drain plug and trans fluid drain plug. I did a google search and couldn't come up with a definite answer. I found a few online retailers that sell "oil drain plug gaskets" but nothing stating that they are specifically for just the "oil drain plug". So I can only assume that these are universal and can be used for both applications
Quick Reply: DIY: G37 Automatic Transmission Fluid Change, Pan Drop/Clean
