DIY: Paint Your Calipers
I finished later on in the evening, so I let it sit over night at least. I wish I would've let the paint sit a little longer before bleeding the brakes though. One of the inside bleeder valves leaked onto the paint a little and ate it away. I just resprayed it a little while it was on the car. You can't tell.
Excellent DIY!
But if i may, i'd just like to add/correct to the DIY.
The FSM calls for this order when bleeding:
passenger rear > driver front > driver rear > lastly passenger front
And for most calipers with two bleeders, bleed the inside nipple then the outside. (Here's my shameless plug for the one-man bleeding DIY).
And for the paint, since you already had it out, popping them in the oven for 20m at 200F would've cured it fast. I used a different paint, took me 17 days to do, but it's on there good and has been track-tested numerous times.
Also, after testing so many different high-temp vinyl's and various oven temperatures, stay away from light colors as they tend to turn brown after a while (I spray-painted mine using stencils instead of using decals).
Was searching for caliper paint and found this site. They have some nice custom colors. If anyone is interested check it out.
Custom Colors On Hand
Great job with the calipers and even better job with the DIY.
__________________
__________________
