DIY: How to install the GT-Spec Tower Strut Bar
Old 10-19-2009, 05:55 PM
  #46
A technical note that wasn't in your DIY: The 6 nuts on the strut towers that hold down the brackets only need to be tightened down to 28 ft/lbs. I had no need at all of the crow's foot and didn't find any of the nuts hard to get to even with a large torque wrench and 3/4" socket. I used a 6" extension to get to most of them and just the wrench/socket for the ones under the bar when it's in place.
Old 10-19-2009, 07:06 PM
  #47
KnoxvilleG37
KnoxvilleG37's Avatar
Thanks for the addition Black Betty! I'll edit my original post.
Old 10-19-2009, 07:07 PM
  #48
Gamedog
Sam Rothstein
Gamedog's Avatar
Gonna install mine this weekend and am gonna use this DIY.
If it's wrong in any way, consider yourself a dead man Knox.
Old 10-19-2009, 07:09 PM
  #49
KnoxvilleG37
I think you'll be pleased Gamedog.
And if not, just blame it on Black Betty for messing with perfection
Old 10-19-2009, 07:11 PM
  #50
Gamedog
Sam Rothstein
Gamedog's Avatar
Haahhahahhhaa
Old 10-26-2009, 08:51 PM
  #51
wireboltman
wireboltman's Avatar
Thank you for the writeup.
It was certainly a nice guide to have.
Took about an hr, I guess
I had no problem using standard sockets and wrenches.
I installed the brackets individually first, and then installed the bar between them.
I also cut the tyrap on the larger hose on each side. I don't know if I'll resecure them or not. We'll see.
They still sit very tightly to the top edge of the bracket. It would only be for looks if I do.
They can't go anywhere, that's for sure-
In my opinion, leaving them in place puts undue strain on the loom and the wiring inside.
The hood closed easily using the 2 credit card spacing, and I saw no mark on the hood insulation.
I didn't have any talcum powder to really check it out, and may get some tomorrow.
I'll recheck for rubbing periodically for a bit.
Old 10-29-2009, 01:16 PM
  #52
wireboltman
The more I think about it, the more I wish I would have painted the brackets black-
Possibly white.
The blue brackets just don't look good, in my opinion, at least not with the white.
I may take it all apart and paint them.
We'll see-
No rubbing on the hood of any kind at all, and given the roads, not likely there ever will be any if it hasn't happened yet-
Old 11-14-2009, 05:44 PM
  #53
Mid-Life Crisis
Mid-Life Crisis's Avatar
Although I've had my bar for months I only installed it today. I had painted the brackets black followed by 3 coats of clearcoat prior to the install.
Most was relatively straight forward but I was unable to get the driver's side bracket to slide on top of the screws while attached to the bar without scratching my Injen intake tubes. I had to install the bracket first.
In order to get it over the strut screws, I had to use a wrecking bar covered with a microfibre towel.
I finally got it all on, but could not reach the 2 credit card clearance guideline - I'm at about 4 or 5 credit cards and yet I'm at the bottom of the adjustment slot. I even tried a small ballpein hammer covered with a microfibre towel. (I can't find my rubber hammer). I think the paint is too thick!
The hood closes easily but I'll have to check for rubbing tomorrow. I have pictures but haven't unloaded them yet.
Old 12-07-2009, 08:59 PM
  #54
G37powa
G37powa's Avatar
i have the same strut bar by GT SPEC... not bad i must say...
did you guys know that GT spec is made by CUSCO?
or the other way around~~ i forgot lolz
Old 02-23-2010, 08:57 AM
  #55
Don Meshal
Don Meshal's Avatar
surely one of the best DIY threads ive seen
easy and simple
Old 03-13-2010, 05:53 PM
  #56
mw09g37
mw09g37's Avatar
my brackets are black and they look Soo good, lol
Possibly white.
We'll see-
Old 05-09-2010, 02:39 AM
  #57
Don Meshal
Don Meshal's Avatar
very neat ..
everything was explained to make it nice and simple
Old 06-20-2010, 06:11 AM
  #58
LiquidPlatg37S
LiquidPlatg37S's Avatar
great write up making me want to get my credit card out now and order from Lou@Amplified....
Old 06-20-2010, 08:10 AM
  #59
hispeed-lowdrag
hispeed-lowdrag's Avatar
Do it man it's really worth it, I love my GT spec bar...and like the DIY suggests, installation is easy!!
Old 11-20-2010, 09:14 PM
  #60
mj_39
mj_39's Avatar
hey guys! Seems like the bar comes with its own nuts? I bought mine used, didnt come with them, can the stock hardware be used to secure the bar?
thanks!
Quick Reply: DIY: How to install the GT-Spec Tower Strut Bar
