Basically i know-how to install but do not know how to adjust. Basically i set the new arm about the length of oem arm then installed. I need a crap ton more negative camber so does the arm need to be longer or shorter? Can this adjustment be made with the arm on the car or does the arm need to be disconnected to make it longer or shorter? Thanks.Just need to not rub so badly on the way to alignment shop 20 min trip lots of dips and bad roads.
It'll need to be longer for more camber. With that said, are you using SPL arms? I believe they're making them in two lengths now. Mine were just about maxed out at -1.6 and they're aware that some G's had longer or shorter OEM camber arms.
