Help What OEM wheels fit a G37S AWD Coupe
Looking for inexpensive second set of wheels so I can run summer tires so I figure Infiniti/Nissan take offs are probably my best bet. I have a coupe with AWD and sport package so I am limited to a square setup. Stock size on all four corners is 19 x 8.5 with +43 offset. My suspension is stock.
Other than from another G37S AWD what are my options?
You could look for older G35 19" Rays wheels, these are light & forged they come in a staggered set usually, but it's a mild 1/2" stagger in a 19x8, 19x8.5 setup. You could run 245/40s on all four (keeping the wider wheels in back). These are a good step up from cast OEM coupe wheels.
All G35 and G37 wheels interchange though you have to watch out for clearance issues if you have the Sport (Akebono) brakes. Since you have the big brakes, both G37 18" (spoked and Duckfeet) will clear as will the coupe 19" wheels and the Rays that Brad noted.
You are not limited to square fitments, you just have to be careful with tire size selection. Square is easier and you can rotate front to back.
Thanks, kind of what I already knew. Been looking for G35/37 locally with not much luck, was hoping there might be some Q series that might fight and clear my brakes? Any thoughts?
Thanks for the input.
My search continues, with a little more focus for an affordable set of rims so I can run different tires for summer and winter.
Here's a nice deal
https://www.ebay.com/itm/Set-of-4-In...UAAOSwWTZchylY
I have been watching here, ebay, etc. but am only interested in local so I can see the wheels first hand, avoid shipping to keep things affordable and like the security of not having to send money over the internet.. I am from Long Island NY, so if someone hears of a set for sale in my area...........
As always, thanks for the input!
nethole
10-27-2017 05:46 PM
