2010 G37x Coupe stock 18 inch wheel tire choices?
Old 10-16-2018, 05:24 PM
Dan G37
Dan G37's Avatar
Exclamation 2010 G37x Coupe stock 18 inch wheel tire choices?
So I'm in need of new tires and was wondering which square setup I can for my AWD system.
I accidentally got 235/50/18's on right now and might return them and change them because of the 1.5% difference from what the stocks were before.
I want to run 245/45/18 but not sure if they are too wide for my car. Any help and input would be greatly appreciated! Also found out that they only have a .66% difference.
Or lastly should I stick with the stock 225/50/18?
Thanks in advance!
Old 10-16-2018, 08:52 PM
MH2013
MH2013's Avatar
You should be fine with the 235s. I have a 2013 awd coupe and ran 245/45 on my stock wheels before upgrading. Had them on for over a year with no issues.
Dan G37 (10-16-2018)
Old 10-16-2018, 11:47 PM
Dan G37
Dan G37's Avatar
Thanks for the reply! Won't the 1.5% difference mess with the AWD system? Also how wide were your wheels? 8'' or 8.5''?
Old 10-17-2018, 06:20 AM
MH2013
MH2013's Avatar
My stock wheels are 8” and have 245 on them.
235s won’t be a problem. The thing to watch for is if you choose to run staggered sizes front to rear. That’s when having different diameter tires the percentage is critical. A square setup where all 4 tires are the same size 1.5% will be fine.
Old 10-20-2018, 04:45 PM
Alakki37x
Alakki37x's Avatar
Same problem
Im facing the same problem with mine, i already have 245/40/R18 winters from my last car and im wondering if its too wide or too thick. Also should i save my summers from my previous car, theyre 255/40/R18
Dan G37 (10-21-2018)
Old 10-20-2018, 08:34 PM
slartibartfast
slartibartfast's Avatar
The 1% diameter differential only applies if you run staggered wheels, you don't want to exceed that difference in rolling diameter for AWD cars.
I've seen 3% tossed about for overall change in rolling diameter, the ECU or TCU stores the OE value for whatever reason.
Old 10-21-2018, 10:37 AM
Dan G37
Dan G37's Avatar
Ahhh got it! Thanks for explaining that! I switched to 245/45/18's and haven't been happier the handling is so nice!
Old 10-21-2018, 10:38 AM
Dan G37
Dan G37's Avatar
I switched to 245/45/18's on my stock 18/8's and they are wonderful! Couldn't be happier!
ronaldvalente
05-13-2014 12:01 AM
BlackGSedaN1027
12-20-2010 08:38 AM
christophercale
11-06-2010 11:23 AM
groinkick
11-12-2009 06:51 PM
UNV-IT46
04-11-2008 03:51 AM
Quick Reply: 2010 G37x Coupe stock 18 inch wheel tire choices?
