Would the Niche Gamma M190 Fit our ca
Hi guys I’m thinking about buying the Niche Gamma M190, but I don’t know if it would fit my car. I have the akebono brakes too. I also don’t know which size would fit, 19 inch or 20
Do you have a Coupe, Sedan, RWD or AWD?
Having the big Akebono brakes will require verifying clearance w/ vendor.
The bolt pattern is correct but that particular wheel (20x10.5 +40) will work in the back on a coupe w/ in-spec camber, might require just a bit more camber on a sedan, but won't work in front on either vehicle as the inner clearance is too tight. I'd consider a staggered setup and run something like a 9.5" width in front.
CrystalTheG (10-08-2018)
nethole
10-27-2017 05:46 PM
Need 4 Speed
Wheel & Tires
17
10-27-2016 01:57 PM
gammamotors
44
12-31-2015 12:48 AM
