Federal 595 RS-RR
so I just ordered a pair of Federal 595 RS-RR for the rear of my coupe, size is 275/35/18. I have a +22 offset wheel.. what are the odds of the tire not fitting? Lol I heard those tires run super wide
Depends on your wheel width, if they're 10" or narrower should tuck ok, if you're running a 10.5 you'll probably contact the fender edge if you run camber in-spec. Also, the 35 series will be quite a bit shorter than your OEM tire size, what tire size are you running in front?
(Post 4214318)
I do plan on getting some federal for the front as well |
Originally Posted by VqLouie37
(Post 4214320)
front 18x9.5 245/45/18 rear 18x10.5 275/40/18 these tires I currently have on are BF Goodrich G-Force sport comp 2. I do plan on getting some federal for the front as well |
(Post 4214321)
It's going to be tight, but if you have a bit of room right now w/ the BFGs you should tuck ok, do you have a section width for the Federals vs. the section width for the BFGs? Should give you a good idea of how much wider the Feds will be. Also, when you get new fronts be sure to get 245/40s instead of 245/45s to keep diameters similar.
(Post 4214324)
now, I’m sure raising the car would help but can I run little to no camber? I’m currently lowered about 2-2.5” and -4 degrees camber |
The section width on the RS-RRs run super wide. My 265/40R18 RS-RRs easily ran about 20mm wider than the set of 265/40 Ventus V12 Evos, so that should give you an idea. Also, the shoulders are a bit more squared off, so you don't get any room there either.
