Service Engine Light/TPMS Light Came on
Hey all,
So a few months ago a lady hit the rear right side of my car, and I got it fixed; fast forward a few weeks later the engine light came on, is there any way to reset the service engine light? Also I recently changed my wheels, and tires from a 17x7.5 to 18x8 wheels and after a few days the TPMS light came on, now everytime I start it the light blinks for about a minute, and is solid. I'm not too sure what to do because I know that if I take it to the dealership they'd charge a ridiculous amount. Let me know.
Thanks
Thanks
Unplugging the battery should reset the Service Engine Light as well as following this video:
https://www.youtube.com/watch?v=95WszTnphPI
I just following him and do it as he does it in the video.
Hey all,
Thanks
Thanks
It doesn't matter if you disconnect the negative, positive or both terminals. If the light stays on than that means you have a electrical/circuit problem.
As for the TPMS light being on, does your new wheels have the correct TPMS sensors in them? The light blinking is a indication that 1 or more sensor is malfunctioning or can't be read.
vq37_ (10-26-2017)
Your check engine light is on because there is a problem. What good are you doing by just trying to turn the light off? You need to get the car checked out to see if it is something minor or major.
Service Engine Soon light is a Check engine light. A check engine light does not come on for routine maintenance.
Also when maintenance is due, you can easily reset it yourself on both the nav screen display and MID display on the cluster.
They are just telling you to take it to a dealership because they don't know anything. What's the name of this shop that you took it to?
They could not be more wrong.
My check engine light came on a few months ago as well. I tried the usual gas cap thing, but to no avail. Took it to the dealer, and it was fixed with some kind of reflash to part of the transmission programming - sounds a little obscure to me, but it fixed the problem and it's never happened since.
