Any issues with these oem Acura wheels on G37xs?
TLX Wheel Specs - Acura TLX Forum
18 inch wheel size - 18 x 7.5 18 inch stock tire size - 225/50R18 All have the same bolt pattern - 5x114.3 All have the same center bore - 64.1mm All have same offset - +50mm The two concerns I have is the +50mm offset which is a lot more than my stock wheels and center bore 64.1mm as I have no idea what that is and what our stock center bore is. Also, would our stock center caps fit on the wheels? I am looking at Acura TLX 18" stock wheels. I think they would look nice for a winter set. |
Our cars have a 66.1 center bore so they would not fit. I believe you can only use adapters for wheels with a larger center bore. The 50mm offset isn't bad, our stock wheels have offsets in the mid 40s.
(Post 4092197)
Too bad. Thanks |
Tire size
I just bought a 2013 sedan. I have four Michelin Premier A/S 225/55R17 that I bought a year ago for a Volvo C30. Can I put these on the Infiniti by any chance?
Thanks (Newbie as of today) |
225/55/17 is the OEM tire size for the G37x. They will work just fine provided the G still has the 17" wheels on it...
I put down the wrong tire size for the Michelins. They are 205/50R17. Yes, the Infiniti still has the original 17" Goodyear tires. Thanks!
No, those tires are not a good size then. Also, if you have a question, dont post it in a totally unrelated thread from a year ago.
Thanks. Why is this
Guess you could see if wheel repair place will rebore it for you if it's not major change
Originally Posted by 2tattered
(Post 4148907)
Thanks. Why is this
(Post 4148955)
Welcome to the site, feel free to post a fresh new thread when you have a question :)
