TPMS And Aftermarket Rims
These are the wheels I am 90% leaning to on purchasing. It comes with the TPMS sensors pre-programmed. What do you think of this fitment? I am unsure whether to get 19" or 20" I do not want to lower the car due to the roads in NY area are garage and I do not want to bend my rims.
I will say though, I think you should spend a little more on tires. Michelin Pilot Super Sports, Continental DW, or Ventus V12 Evo tires are some popular choices. I have never heard of the tires you posted before. If you want All Season tires instead the Continental DWS are a popular choice.
Pyroclastic Flow
Steven -
+1 on the 245/40s. I have 'em they are perfect for a square setup on the X sedan (I know you have a coupe...so there's that...).
And I suspect those wheels can only be rotated front-to-back. No cross-rotate there. Do consider one of the tire choices that Jumbo mentioned and the Bridgestone Potenza S-04 Pole Position . You won't regret it.
Otherwise they look great and should serve you well.
Sean
Sean
thank you everyone for their advice an input. Of course I have a few more questions.
1. 245 vs 225. Can anyone source a picture? Even if the rims are designed for 225, 245 tires will still fit the rim?
2. If I were to drop the car with the Eibach springs, would the fenders clear the width of 245 tires? Will they clear diameter of 20" wheels?
3. Can anyone help source a pic of the G37 on aftermarket 19" wheels with OEM suspension? I feel it looks "off" and a drop to minimize the wheel gap will be needed to complete the look but I am unsure.
2) Yes and Yes. 245/40/19 is a common setup for 19" wheels on lowered suspension. Ridiculously common. Search around the forum and you will find examples no problem. The 35mm offset is conservative enough that you should avoid rubbing. If you want to go 20s you should get a tire with a thinner sidewall to keep the overall diameter of the wheel the same as the 19" wheels. probably 245/35 but I am not sure on that one. I always thought 20s were too big so haven't read as much on those setups for our cars. Going with 20s would not make the wheel stick further out towards the fender unless you go to a 20/9 or 20/9.5 wheel
Note, the ride will be harsher with 20" wheels and thinner tires. That in combination with the springs might not be what you're looking for since you'll be doubling up on the harshness and you mentioned bad roads in your area. To get this answered by the experts post in the Official I have a wheel/tire fitment question thread in the wheel and tire forum. Blnewt or some other kind user will probably stop by and give advice. FWIW I live in NJ and am on Swift lowering springs. Comfy ride without going too low. Feels almost OEM.
3) It does look off, just less bad than 20" rims on stock suspension. The general rule is suspension first, wheels second. Bigger wheels on X oem suspension will NOT give you the tighter, more aggressive look you want.
Thank you for the advice. I guess I will be going with 245/40/19 setup and purchase lowering springs. How much was it to install the swift loweringsprings, ballpark?
Camber kit is to keep the alignment in spec after the lowering. Some people need it, others don't. I preferred to be safe. If you want to go that route your best bet is the SPC parts. I bought mine here.
Combo Packages 2 Rear Camber Arms w/ Toe Bolts + 2 Front Adjustable A-Arms (Complete set for whole car front and rear) INFINITI G37
There are some threads around the forum about the trimming of the toe bolt slots to allow for the full range of adjustability. Check that out to make sure you or your shop knows what to do.
Up to you man, hope I helped. There's no cheap way to go about this if you want to do it right.
The Steering Wheel Guy
No one wants to lower their car, it's just that no one wants the wheel gap. lol
You can either pay now or later when it comes to purchasing camber kits. Buy them now, or buy them later along a new set of tires that were detroyed from excessive toe and/or camber.
The following 2 users liked this post by Ryne:
JUMBO PALACE (02-17-2016),
VIVID (02-17-2016)
I understand. I mention the camber kit because it is commonly paired with lowering springs, especially the eibachs, which are a deeper drop than the swifts. Your lowered suspension will throw your tires out of alignment eating up tread and maybe even putting you in a dangerous situation.
Pyroclastic Flow
You have helped a lot lol. I didn't realize that Eibach was a deeper drop then the Swift springs. I can always just lower the car at a later date. Purchase the wheels first, determine how awful the wheel gap really is, and go on from there. I have many more mods I want to do to the vehicle, investing over $3000 at least in suspension and wheels is a lot of money.
But rarely in this hobby are you able to combine aesthetics and performance in one package to such a degree. It really is a lot of bang for the buck. Good looks and great handling.
And please don't forget the sways.
Sean
