25+20mm wheel spacers on G37 Sedan
10 Attachment(s)
I searched high and low for pictures of a g37 sedan with 25mm spacers up front and 20mm in the rear on stock staggered 18s and couldn't find any, so I figured I would post my results in case any one else was looking to do the same.
Car is lowered on Eibach springs Don't mind the filthy car with bugs all over the bumper :D Thanks to tmmmmt for the spacers. :biggthumpup: Before/After Attachment 187022Attachment 187023 Attachment 187024Attachment 187025 Attachment 187026Attachment 187027 Attachment 187028Attachment 187029 Attachment 187030Attachment 187031 |
looks good! spacers take a car's appearance to the next level. I did 20mm all around on mine, with sprint springs
have you had the chance to see if your in spec with aligment? got any camber kits for front or back or both?
(Post 3783964)
nice I will stay tuned as im on the same drop, but havent purchased any spacers as Ive been on the fence about them for the longest. Thanks
looks good. Pretty aggressively flush in the rear. Any other side shots and other perspectives overall?
1 Attachment(s)
Originally Posted by rm2342
(Post 3784275)
Attachment 187021 |
That looks real good, OP. I've been considering spacers for my duckfeet & snows when winter comes back around. Good to see what it would look like on another MW Sport.
(Post 3784490)
And BTW, really good job on Before/After perspectives. Those are freakishly similar camera angles and depths.
(Post 3784505)
looks good....now time for 19s! :)
That looks really good. Has anyone seen spacers on a G37S sport (non-AWD) with no drop? A friend at work put a 15mm/20mm combo on his coupe (19 inch sport wheels) and it with no drop and it looks lowered now as pushing the wheels outward seems to reduce the visual wheel gap.
I've got the G37s coupe wheels on my sedan with Tein S-Tech springs. Looks really good now but I bought 25mm spacers for the front and 20mm spacers for the rear because the wheel width difference...hoping to get the flush look. I'll post pictures when I get around to installing them. Should be soon...hopefully...in theory...
Geeze... I forgot about this thread. Nice to see it bumped up for attention.
Still planning on spacers for my duckfeet come winter, dropped on Swifts. And I keep going back & forth between front/rear: 15mm / 15mm 20mm / 15mm 20mm / 20mm 25mm / 20mm I suspect I'll be mounting the rims first before buying the spacers, just to eyeball the situation. 25mm is a pretty significant size spacer. |
