Volks TE37 18" 9.5/10.5 +22 all around for 08 G35 Sedan
Ok .. I think i figured out the fitment:
19X9.5 all around.
but still studying on the offsets ..
based on that black Sedan on the three pictures above, what offset do you recommend ? rears seem to be ok with that +34 ( or can i go a lil lower, need them to stick exactly along with the fender's edge ).
how about fronties ?!! especially i jumped from 8.5 to 9.5 now.. what offset do you suggest ? thx in advance
19X9.5 all around.
If you want to go completely square (all same wheels & all same tires) you could accomplish this easier w/ different front offsets, something like +38 front +30 rear on 245 or 255 all around or keep all offsets the same and use a small spacer to bring the rear out w/ offsets in the +38 range.
Personally I think you found some great fitment on those sedan pics and going w/ that same staggered setup would be my choice. Plus you can go pretty wide rubber in back for a more aggressive stance.
blnewt .. Thanks a lot for standing on top of my thread, i really appreciate it.
Ok bro.. I'll go for square look at 19X9.5 all around, so that means i go for +38 front and +30 on rear, right ? or you said i keep them all at the same offset..What offset did u mean? sorry i got confused
Ok before i get you confused too :
This is what i'm going to do, i'll go for 19X9.5 all around like i said above.
i'll keep the rear at +34 offset and i'll use 5mm spacer.
As for the fronts, i'm really not sure.. lets just focus on fronts now:
what offset do u recommend, rememebr they're 9.5 now ( before they were +28 at 8.5 on that pic ).
Say i decide to keep them staggered .. 8.5 on front, what offset do you reommend now ? rememebr it's on +28 already.
So .. what i need now is to figure out the best offset of fronties when they are at 8.5 and 9.5
If you decide to go staggered shoot for the same specs of the sedan pics you posted since that seems to be the fit you're looking for. Then just do a little math to get the same fit for a square setup. If you go an inch wider rim in front this will essentially add 12mm to the offset so~
8.5" +29 would need to be a +41 for an identical fit in the front
The rear is already a 9.5" and a +34
If you want a square set at 9.5" you can go a 9.5 +40 in front and a +34 in rear
You can also go +40 on all 4 wheels and use a 5mm spacer in back to get the same fit as your sedan pics.
FWIW here's a sedan lowered on Swifts (similar drop to Eibachs) on a square 19x9 +35 245/40/19 setup (no spacers on his car)
https://www.myg37.com/forums/g37-sed...-thread-2.html
You're right, I am officially confused now
you've helped enough n i can't thank you for that enough..
I really appreciate it, now i'm going to decide myself on which option to go. Once again, Thank you
That guy on 20" btw
Race, repair, repeat.
The second sedan is mine.
If you want to run staggered and standard size tires (245/275) then get 9.5 +32-37f and 10.5 +42-47r.
If you are going to do square with standard tires I would do 9.5 +32-37 all around.
If you want aggressive with a slight stretch (225/255) then go for the specs I mentioned previously 9.5 +24-26f and 10.5 +30-32r.
Skyrhino (03-14-2016)
FWIW here's a square setup w/ 19x9.5 +22 on 235s
https://www.myg37.com/forums/3693432-post2058.html
https://www.myg37.com/forums/3693473-post2061.html
Thx for sharing those, they look really nice
Oh btw..my second option is Work Ultimate CR (Kiwami) .. if they were just less than 25lbs..
Anyhow, I'm planning to place my order on chrismas only, so let's see what i end up with.
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
