19" WedsSport SA-55M
I need to find some rims asap, I got a free set of (4) 245/40R19
The car is on stock suspension for now I might install lowering springs after I get the rims I'm not sure to what size and offset to get, I have an 08 G37 coupe and not sure fitment would be. Should I run the same size all around or staggered even though all the tires will be the same size? Also I dont want to run INSANE amount of camber to make it fit a wide rim fit. If I run +15 offset do I have pull the fenders dont want it to poke out too much http://www.evasivemotorsports.com/mm...-sa55m-bbm.jpg 19x8.0 / 5 x 114.3 / +35 (Black Blue Machining) 19x9.0 / 5 x 114.3 / +38 (Black Blue Machining) 19x9.5 / 5 x 114.3 / +15 (Black Blue Machining) 19x10.5 / 5 x 114.3 / +15 (Black Blue Machining) 19x10.5 / 5 x 114.3 / +24 (Black Blue Machining) |
they make them in 9.5 +24 as well and that's the setup you'd ideally want.
9.5 +24 front 10.5 +24 back.However, you cannot run these measurements without a spring/coil drop (they'd look extremely awkward and will stick out too much). if youre on stock suspension you have no choice but to go 9.0 +38 front and 10 +40 rear which fits similar to oem (less tucked in but still tucked in). your problem is going rim -> suspension. you should be considering suspension -> rim. good luck |
