19x11 + 25 rears on a sedan
11-09-2011, 01:10 PM
Can I make this work with negative camber and stretched tires?
11-09-2011, 01:21 PM
Florida G Club
11-09-2011, 01:37 PM
11-10-2011, 08:50 AM
11-10-2011, 08:53 AM
Florida G Club
Because Math. Wheel too big.
11-10-2011, 10:06 AM
Camber, Stretch, Roll, and Pull
11-10-2011, 12:23 PM
Quote:
Originally Posted by
fairladyz34
^ that should work... im running 20x10.5 +25 on my sedan with a mild fender roll, -2.3 camber and most people say my tires aren't stretched...
11-10-2011, 01:10 PM
So that would be like a 19x10.5 +19 it'll work if you roll the fenders
11-10-2011, 01:39 PM
ugh idk what to do haha i wanna go aggressive
11-10-2011, 04:10 PM
MYG37.COM Platinum Sponsor
Seems quite aggressive to be honest.
11-10-2011, 04:39 PM
Anthonyg37x
FWIW,
here's mine on x10.5 +45 w/ 285 tires. Camber is at -2.1
ish and minimal drop on BC's. Yours would extend out another 26mm.
Deception
Do you have photos of how your roll looks? Mine rubs with the above specs, trying to figure out the best way to fix it.
Thank you.
11-10-2011, 05:04 PM
your best way to stop the rubbing on urs is a different size tire. with the rears you should be running a 255 or a 265.
11-10-2011, 05:08 PM
^put a smaller tire on. If you don't want to stretch a 265 will still give u more clearance. If you want to stretch them you can run a 255 or 245 on a 10.5
Edit: terrific beat me to it lol
11-10-2011, 05:57 PM
I would be runnin 255/35 in the rear
11-10-2011, 07:40 PM
TeRRoRiFiC35
fairladyz34
Anthonyg37x
Those aspect ratios are a little too short for a sedan, no? It'll clear for sure.
