I've noticed something...
So after I put on my Vossen cv-1, I've notice that my ride is been much rougher. So my stock wheels(17s from the Sedan G37, I know the ripped me on my wheels) and I've seen it gets a little less MPG on my new wheels. Also driving it pulls left or right much harder when on a little rough pavement. So I was thinking is this from the heavier wheels? Or is it just less tires then the 17s wheels?
well what tires did you get with your cv1's?
Originally Posted by Pcasey
(Post 3104883)
well what tires did you get with your cv1's? did you get an alignment after you put ur wheels on?
It was good year. Forgot the specs, but yes it had the alignment. |
Why did they "rip you on the wheels?"
I'd go back to whoever mounted and balanced your wheels. Hopefully you went with new tires. |
I hope you didnt go cheap on tires, bad mistake
Yes they are brand new tires. All seasons good year.
Originally Posted by seasonalocean
(Post 3104877)
bigger rims less tire = rougher ride
Originally Posted by breftayka
(Post 3104893)
I mean, I bought the G used. But only came in 17' wheels, which is not standard in the G but ohh well. More reason to buy newer wheels right? lol |
all seasonal tires from bridgestone? with cv1's. check what size they are.
Then my next question is, why the less gas mileage then before? I was getting around 24 MPG now I get around 19. Maybe cause wheel little heavier?
Lower profile tires = shorter sidewalls = harsher ride.
To figure out your true MPG, you first have to determine if your new tire/wheel set-up is the same overall diameter as the OEM tire/wheel/ set-up. If they are not identical, then you calculations will be off. |
So here are my wheels set up.
Vossen VVSCV1 Size/offset: F: 20x9 +20 / 20x10.5 +15 Finish: Matte Silver w/ stanless lip Front: Barum 245/35zR20 95y rear: Good Year eagle GT M+S 255/35zR20 97w |
What .......
What am I missing?
| All times are GMT -4. The time now is 11:25 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
