tpms install
if i get new tpms does it automatically connect with my computer or do i have to get it reprogramed..
Thanks |
I'm pretty sure they will need to be reprogramed
You'll need to take it to the dealer and have it "registered" to the computer.
i believe if you get OEM tpms, then it will sync automatically.
Originally Posted by beerme986
(Post 2847852)
Apparently the computer can only see one set of sensors at a time though, which sucks since every time I switch between wheel sets I have to take it into the dealer to have the sensors re-registered. |
Every time a sensor is introduced (oem to second set, second set to oem, etc) they need to be registered at the dealer or with our Quickset tool.
maybe im not reading this right but ..if we use the OEM sensors that came with the car, move them to new wheels, do we have to get them reprogrammed?
(Post 2851428)
I got a question...If I swap my (A) wheels to (B) wheels without programming the (B) sensors, would my (A) wheels sensors still work if I decide to switch back?
Originally Posted by Neal@tirerack
(Post 2851330)
Originally Posted by Blackjack
(Post 2853033)
Can you post some information on this Quickset tool, Neal?
Originally Posted by Gunit37
(Post 2853029)
(Post 2853036)
What questions on it do you have?
No. You have to reset the B sensors so they are recognized while using them, then have to rest to the A sensors once you put them on. Every time you reset a new set to the car its wipes out the previous set. Only a few cars, like the IS350 I had, have an A/B sensor button on the dash so you program once and switch between the two sets. |
+1 on more info about quickset tool. but I found the following link for infoin the meantime: ATEQ TPMS Quickset Tool
seems like a worthwhile investment for those with winter and summer wheels. |
(Post 2853044)
What if I drive with B wheels without getting the sensors programed, lets say two days later, I put my A wheels back, would A sensors work?
(Post 2853177)
Neal,
The Tire Rack website says that 2010 G37's cannot use the ATEQ Quickset tool. They have to go to the dealer to be reprogrammed. Is this correct? |
