Time to change my tires, need help really bad !
Old 01-15-2010, 12:27 PM
Khalid-NS
Khalid-NS's Avatar
I have a G37 08 with the 19" stock rims, i reached 33,000 miles now "thats alot i know !" do you guys recommend any good tires with a nice price tag ? i dont have any experience in this field. Thanks !
Old 01-15-2010, 12:33 PM
ucla bruin
ucla bruin's Avatar
Do a search for Yokohama S drives. Good tires for a good price. Many members have them, including me.
__________________
Old 01-15-2010, 12:36 PM
Khalid-NS
Khalid-NS's Avatar
Thanks,how much did you get them for ? and do you know a good place to get them and install them at in the OC ?
Old 01-15-2010, 12:47 PM
vinnys coupe
vinnys coupe's Avatar
Yokohama S.drive off tire rack.com. Brian does $200 a tires sound around right?
Old 01-15-2010, 01:00 PM
+1 on the Yokohama S drives for a good replacement tire that won't hurt your wallet. You should be able to get them for around $800 to $900 a set.
If you have NTB in your area, they can order them if they're not in stock.
Old 01-15-2010, 01:05 PM
ucla bruin
ucla bruin's Avatar
I got mine locally through a friend but I believe Tire Rack has pretty good pricing. You can call them or PM their rep on the forum.
Mine were installed at Wheel Wherehouse in Anaheim because that's where I got my alignment too but any shop should be able to install them. I'm at around the same mileage as you
__________________
Old 01-15-2010, 01:17 PM
Khalid-NS
Khalid-NS's Avatar
I think i will go with the Yoko's , the size i should get is 245/45R19 correct ?
Old 01-15-2010, 01:46 PM
Krebo
Krebo's Avatar
make sure your tires arent staggered...
staggered sizes are Tire Size Front: 225/45-19 | Tire Size Rear: 245/40-19 (change)
Old 01-15-2010, 03:26 PM
xyz
xyz's Avatar
Imo, if you put a lot of miles on ur car, then go w/ the Yoko S Drives. If not as much, go w/ Hankook Ventus v12 for better performance at the cost of shorter life.
If you order through Tire Rack, I have heard good things about Shoreline Motoring in HB . . .
Old 01-15-2010, 03:34 PM
GiGGaplease
GiGGaplease's Avatar
order tires on ebay. no taxes and its cheaper then other places. i got my yokohamas/kumhos for about 400ish for a set of 20's.
225/40 fronts and 245/35 rears for stockies
Old 01-15-2010, 05:10 PM
Neal@tirerack
MYG37.COM Platinum Sponsor
Neal@tirerack's Avatar
S-Drive is a great tire, B-Stone RE760 a great tire as well for summer use. I don't show they make the S-Drive in the stock 225/245 combo, however.
Old 01-15-2010, 05:21 PM
madmax2k1
madmax2k1's Avatar
Check out this site; they have pretty low prices on tires:
tires online @ tires-easy.com: cheap passenger, summer, winter tires and tire dealer
Old 01-15-2010, 06:38 PM
Khalid-NS
Khalid-NS's Avatar
thx guys. What do you think about this combo 245/40 & 275/35 ?
Old 01-15-2010, 06:43 PM
wakeboardr116
wakeboardr116's Avatar
^Thats the exact combo i have in the S Drives and it is GREAT.
Old 01-15-2010, 07:14 PM
G2Envy
G2Envy's Avatar
Bridgestone is no longer making the 760's in 275/35/19's anymore. I was set on getting this but had to settle for the S Drives. I guess they don't like making that size rear? *shrugs*
Quick Reply: Time to change my tires, need help really bad !
