275's / 20mm Spacers / Stock height = Rubbing!
Hey guys,
I just recently put on my Ichiba 20mm spacers and also threw on some 275/35/19's RE050A's on the rear of my car. It looks amazing, sits very flush. I'm still on stock ride height with the Eibach Pro Kit in mind for my lowering needs. Now as it is I have slight rubbing on heavy dips and bumps. I'm afraid that once I get the Pro-Kit installed this rubbing issue will intensify and that's NOT what I want. I've heard of many people on these boards who are trimming the felt inner lining to take care of this problem. Anybody have an FYI? or can give me some pointers on how to do this without totally ruining the lining itself? Maybe you guys can also post pictures of the trimmed lining? Any bit helps! Thanks! |
here's an idea...275's/15 mm spacer/ no Rubbing..just a thought
^ +1............
interesting info. sam is running 275s with eibach and 20mm and he rubs. so im going with 15mm all around with my eibach drop and 245/275.
I tried to tell everyone not to go more than 15mm but no one ever listens.:confused2:
I will buy your spacers off you :)
Originally Posted by Kidcane
(Post 2620445)
I tried to tell everyone not to go more than 15mm but you no one ever listens.:confused2:
15mm would definitely work better but I don't think it's aggressive enough. I'm looking for mean offset without rubbing. I think with a little modification we'll be on our way. Thanks but no thanks the changing of spacers suggestions guys. :)
ya then trimming the liner is your best bet. dont forget you can also add some negative camber.
i just ordered my 15mm. :D |
| All times are GMT -4. The time now is 12:45 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
