If I were to get 20x9.0 offset-42 (front wheels) and 20x10.0offset-42 (back wheels) with 245/40-20 tires (front) and 275/35-20 tires (back). You think this setup will cause any problems like rubbing or loss in confront? BTW won't be lowered due to too my uneven road and obstructions on road.
i really think you should get something alittle more aggressive than those offsets so you'll have no regrets. and forget about the spacers, they only pushes your wheel out more for an more aggressive look. just get the correct offset so you won't need them.
Im new to car terms, but what exactly does spacers do?
tucked?
sorry guys im so confused....
Most people want their wheels to sit flush with the fender. "Tucked" would be set in under the fender. Spacers go between the hub and the rim and push the rims out so they are not "tucked".
spacers will put the rim out more, so if you have "tucked" rims they will sit more flush or be more aggressive (stick out) with the fender
PIAA Super Rozzas,I like these wheels a lot and only since one person on here (sumo8me) with them.
I also like that look....just want to know how to get it...
A more "aggressive" offset, meaning that the wheel is designed to stick out more. A lower offset number. Mine are +32/+34.
Play around with this wheel offset/tire size calculator and see what will work well and what maintains the same overall wheel circumference. Factory wheel specs are here.
Keep in mind that any 20" wheels you buy will result in some sacrifice in ride comfort because the tires will have shorter and stiffer sidewalls transmitting more of the road to you in the car. You will feel dips, bumps, holes, etc. more than before. The general ride will be somewhat stiffer too. It's the sacrifice you make when going to a bigger wheel size with lower profile tires.
