MyG37
MyG37 (https://www.myg37.com/forums/)
-   Wheels & Tires (https://www.myg37.com/forums/wheels-and-tires-307/)
-   -   Help! Low pressure light won't reset :banghead: (https://www.myg37.com/forums/wheels-and-tires/175584-help-low-pressure-light-wont-reset-banghead.html)
kappa88af Nov 26, 2007 10:39 PM
I noticed the low pressure light come on two days ago. I check the pressure in all tires and set them to 35psi per the manual. I followed the manuals instructions but the light will not go out. I called the dealer and they told me to use another tire gauge to check the pressure which I did, still no luck. Any one have any suggestions, I'm trying to avoid going back to the dealership if possible
speedracer g37 Nov 26, 2007 10:52 PM
the dealer may have to reset it.
MUSCARLIVE Nov 27, 2007 01:48 AM
I have the same problem but I will just wait until I go in for my first service does not really bother me
speedracer g37 Nov 27, 2007 02:28 AM
my g35 always had this problem with the first few days of cold weather. i always had to take it to the dealer for the fix.
Blackjack Nov 27, 2007 06:34 AM
I normally had to drive my G35 around for about 10 - 15 minutes and it would clear itself out. Did you try this?
0to60 Nov 27, 2007 08:59 AM
I had this too at first cold weather. I "aired up" to 35 psi...manual says the light won't clear until the car has been driven up to 16 miles per hour (weird). I did this and the light went out. You have to drive it to clear it.
Callaway Nov 27, 2007 09:13 AM
^^exactly. My recent trip to northern Maine triggered this light. I topped off air to all four tires and the light went away after driving around for a little bit. If it stays, on, there may be something else wrong.
kappa88af Nov 27, 2007 10:19 AM
Thanks guys for the replies. I have done everything you all mentioned. I am taking it to the dealer on Wednesday. Heck, its under warranty. :)
UNV-IT46 Nov 27, 2007 10:05 PM
i'm having the same problem. But mine came on with no pressure change in the tires. they are all still the same...
kappa88af Nov 30, 2007 02:20 PM
Hey UNV-IT46...take it back to the dealer.
On my second trip back to the dealer they discovered the right rear sensor was bad. Thanks for a warranty.
carmeljoy Dec 1, 2007 11:33 AM
i have the same problem with the maintanence oil pressure light. i change my oil and tried to reset but it keeps comming back on everytime i turn the car on. any suggestions?
dzine07 Dec 1, 2007 02:55 PM
+1 yup same here. 34-35 PSI plus 15 miles -and ur good.
BTW,
do you have stock wheels? or did you swap wheels? if not then just drive it for a bit. if u do have new rubbers or rims, reset it.
© 2026 MH Sub I, LLC dba Internet Brands
