MyG37
MyG37 (https://www.myg37.com/forums/)
-   TSB - Technical Bulletins (https://www.myg37.com/forums/tsb-technical-bulletins-12/)
-   -   [TSB] 2008 G37 Coupe TSB's (https://www.myg37.com/forums/tsb-technical-bulletins/201631-2008-g37-coupe-tsbs.html)
daveinli Nov 17, 2009 08:31 AM
09-025 05/12/2009 Antitheft - Windows Move When Closing Glove Box
09-009 02/10/2009 Brakes - Front Brake Squeal/Squeak
09-004A 02/09/2009 Navigation System - Screen Freezes/Locks Up
08-046A 02/02/2009 Steering/Suspension - Vehicle Pulls/Drifts Left/Right
09-007 01/30/2009 Brakes - DTC C1142/ABS, SLIP, VDC OFF Lamps ON
08-018B 01/13/2009 Drivetrain - Rear Axle Clicking Noises
08-037B 01/12/2009 Audio System - Radio Won't Scroll Through All Presets
08-051 12/10/2008 Keyless Systems - Intelligent Key Inoperative
08-028 06/09/2008 Engine Controls - Ticking/Tapping Noise from Bank 2
08-011 02/22/2008 Electrical - Relay Box Cover Replacement
07-048A 02/21/2008 Engine Controls - Engine RPM Increase While Braking
07-043 11/12/2007 Body - Quarter Glass Moulding is Not Flat
07-025 09/06/2007 Body - Erratic Door Window Operation
07-035 09/06/2007 Body - Erratic Front Door Window Operation
00-024E 08/08/2007 Brakes - Judder/Noise/Pedal Feel Diagnostics/Repair
rapidshare.com/files/308448933/ITB09-025.pdf
rapidshare.com/files/308448934/ITB09-009.pdf
rapidshare.com/files/308448935/ITB09-004a.pdf
rapidshare.com/files/308448936/ITB08-046a.pdf
rapidshare.com/files/308448937/ITB09-007.pdf
rapidshare.com/files/308448938/ITB08-018B.pdf
rapidshare.com/files/308448939/ITB08-037.pdf
rapidshare.com/files/308448940/ITB08-051.pdf
rapidshare.com/files/308448941/ITB08-028.pdf
rapidshare.com/files/308448942/ITB08-011.pdf
rapidshare.com/files/308451622/ITB00-024e.pdf
rapidshare.com/files/308451623/ITB07-035.pdf
rapidshare.com/files/308451621/ITB07-043.pdf
rapidshare.com/files/308451619/ITB07-048a.pdf
G37Sam Nov 17, 2009 09:11 AM
Thanks for the compilation! Would sure come in handy for many of us in here
l2awin Nov 17, 2009 09:44 AM
i cant access the files
daveinli Nov 17, 2009 04:20 PM
rapidshare
it is not the file
did you read what it said
"There are no more download slots available for free users right now. If you don't want to become a premium member, you might want to try again later."
GeeeeOhhhh Nov 18, 2009 01:18 AM
if your tired of rapidshare you can download the pdfs here.
G37 Recalls and Technical Service Bulletins | Team LA:G's
daveinli Nov 18, 2009 07:09 AM
tsb
thanks for posting the links somewhere other then rapidshare
pdarby Mar 11, 2010 04:46 PM
Is there a TSB for the battery? I don't see one listed above and would like to get that taken care of before an upcoming road trip.
fmrlegend Mar 16, 2010 09:37 PM
yes there is.... reference: ITB10-010a.
i just got mine serviced yesterday. reprogram ECM, replace BCM.
Lije Baley Apr 11, 2010 01:36 AM
I've been following this problem in the "electrics" forum, but not so much here. My dealer followed the TSB protocol as I described in another post. I hope Infiniti has fixed this aggravating issue.
It seems that dealers nationwide are following the same remedial procedures.
Buckeye G Mar 17, 2011 10:48 AM
I just had the VVEL clicking TSB done and was talking to one of the techs and he told me they put a revised version of the first one. He said he stopped putting the first version in becasue it made the car so sluggish.
Bryanrsx Nov 10, 2011 07:25 AM
I just had this TSB done to my car and feel the same sluggishness. Of course the dealer says it is in my head and that the fuel mapping and ecu just need another reset. Would you tell me which dealer fixed this? I am thinking of taking my car to a diff dealer.
BH818 Nov 14, 2011 10:37 PM
I have the same problem, I'll hook the Nissan console III at work next oil change update the ECU (if it needs to be) and do an Ester oil change (REDLINE 5w-30). Hopefully it fixes it, stupid car sounds like a diesel truck
Bryanrsx Nov 16, 2011 11:36 AM
are you getting the slugishness? also my car is now running about 1-1.5 mpg LESS fuel economy. Dealer seems clueless about 'revisions'
onehighfocus May 1, 2012 02:16 AM
Here's a working list of TSB's
Infiniti G37 Technical Support Bullitins
TexasBadAss Aug 30, 2012 02:02 PM
My Warranty Work at Dealership
I have gotten my Cats Replaced at the dealership. The clicking noise I heard they said was my Y-Pipes. They said there was a small staple. They Replaced under warranty. My cats all the way back to my exhaust! (:
The Trick is to find you a Good Dealership with high customer Satisfaction! And a good service Adviser.
I actually had to just make a call into the Infiniti Customer Center, and within a few days the GM of the Dealership Service Department called me and over the phone approved most of my problems.
I know guys don't bash me because I'm new on here; But I've gotten over $15,000 of free warranty work done on my car and they are all Very Recent, as I just bought my car a few months ago. I have all TSB's and Warranty papers on all of the work I've gotten done at the Dealership--
Just to name a few... Cats, Y-Pipe, Exhaust (muffler), Bottom Seats (the whole seats, not just the cushions and foam, $2600 a pc plus labor; and not just the driver side, I got both replaced because they wouldn't of matched), Aluminum door panels (both; they were scratched/pealing), Steering Wheel, Free alignment (when they put the steering wheel on it wasn't straight), Fixed noises from Front dash and pass. windshield, Replace my front AND rear Brakes AND Rotors (squeaking noise in reverse), Replaced vinyl around dash, and around center console (did not line up good), Fuel Sensor Replaced. There's more I got done, LOL
:icon17:
Feel free to ask me what to say to get these things done by dealership.
I am very picky and anal LOL, and I did a lot of research before going in.
And don't forget to give your service adviser a good review on the survey!!
They will take care of you if you do I promise!!
© 2026 MH Sub I, LLC dba Internet Brands
