09 G37X AWD TSB's
09-032 06/24/2009 A/T Controls - Harsh 4-3 Downshift At 30-20 MPH
09-010A 06/05/2009 Engine Controls - MIL ON/DTC P0116 Store 09-028 06/03/2009 Engine Controls - MIL ON/DTC's P0101/P010B Set 09-025 05/12/2009 Antitheft - Windows Move When Closing Glove Box 09-009 02/10/200 Brakes - Front Brake Squeal/Squeak 08-046A 02/02/2009 Steering/Suspension - Vehicle Pulls/Drifts Left/Right 09-007 01/30/2009 Brakes - DTC C1142/ABS, SLIP, VDC OFF Lamps ON 08-018B 01/13/2009 Drivetrain - Rear Axle Clicking Noises 08-051 12/10/2008 Keyless Systems - Intelligent Key Inoperative rapidshare.com/files/308459736/ITB08-046a.pdf rapidshare.com/files/308459737/ITB08-051.pdf rapidshare.com/files/308459738/ITB09-007.pdf rapidshare.com/files/308459739/ITB09-010A.pdf rapidshare.com/files/308459740/ITB09-028.pdf rapidshare.com/files/308459741/ITB09-032.pdf rapidshare.com/files/308461043/ITB09-009.pdf rapidshare.com/files/308461044/ITB08-018B.pdf rapidshare.com/files/308461042/ITB09-025.pdf |
if your tired of rapidshare you can download the pdfs here.
G37 Recalls and Technical Service Bulletins | Team LA:G's |
sounds good to me
Don't suppose that the transmission sensor on the center console going bad is ever going to be recalled on 09 g37xS's yet? Luckily I am a 4 time g series owner and as soon as I noticed it adapted to using my paddles once I switched to sport and it is buying me time before I can get several other issues taken care of. Or recalled the stupid window wiring which will suddenly decide to open my passenger side rear window at random and not reply to the switches? The normal fix for that isn't working either? Even though the motor is fine and I can roll it up by holding the key in the lock position.
| All times are GMT -4. The time now is 05:12 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
