Tsb-2007-2008 Infiniti G35/g37; IpodŽ Disconnects While Driving
1 Attachment(s)
A new TSB.
Mine just did that yesterday. Back to the dealer i go.
Nice find, bboy.
TSB for "IPOD not Connected"
I get this with both of my Ipods intermitently
The 160 gb will only cut out for a second or two and then come back, the 60gb for a bit longer Doesn't happen every ride and might be difficult to recreate on demand but I did a serach here and a TSB is mentioned where a new cable is needed Has anyone done this and did it fix this issue? Thanks E |
Get it on my 8 GB and 16 GB touch too from time to time.
Is this replacement cable simply the one connecting to the ipod itself?
From models built before JNKCV64E(*)8M 127835
will the new cable recharge the new 3g i phone?
^^I've been told no because the new IPod does not charge though that connection anymore....at least that is what I was told.
^ It's true. I have an iPod Touch 32GB 2nd Generation and it gives me a message sometimes that says something about the accessory will not charge the device. Very annoying. :\
That happens to me occasionally, I've even had my iPod replaced because I thought it was skipping.
Originally Posted by ObsidianGT
(Post 2461273)
The iPod interface on the G37 with Premium Package is not meant for charging anyway, but when the older iPods were hooked up there was a "trickle charge" that would keep the battery topped off. Apparently that trickle charge was Firewire-based. http://support.apple.com/kb/HT1476 Apple has a third-party adapter by Scosche called a "PassPort". It's an inline adapter that passes the audio signal and adapts a USB charging port. There's a possibility that the Kensington 4-in-1 car charger might work, too. It shouldn't be too bad since we already have a 12-volt power port below the iPod interface in our cars. |
I have a 2008 G37S coupe with premium package and an iPod touch 3rd gen (32GB model) with v3.1.2. firmware. Whenever I connect the infiniti provided iPod cable, I get a message on the car screen, "There is no song" and I am not able to use any of the controls in the car to navigate the songs on my ipod. Even though I do have songs. Based on all the posts I've read about charging the newest line of iPods, if I bought one of the following from of the links provided below, will this also fix my "There is No Song" message?"
- Scosche Passport - Charging Adapter - CableJive Charge Converter - Charge Converter - CableJive - Ridax Charge Converter - Redirecting you to Ridax programutveckling |
Originally Posted by XLR8G37
(Post 2841929)
Can anyone tell me what model/year iPods would allow charging? It's annoying and basically worthless if I have to take my ipod out all the time to charge it.
