MyG37
MyG37 (https://www.myg37.com/forums/)
-   Supporting Vendors (https://www.myg37.com/forums/supporting-vendors-30/)
-   -   Vendor KW Lowering Coilover Kit for Infiniti G37 at CARiD (https://www.myg37.com/forums/supporting-vendors/285475-kw-lowering-coilover-kit-for-infiniti-g37-at-carid.html)
carid 11-14-2017 10:48 AM
If you've been thinking about dropping your G37 several inches lower to the ground, yet still not quite sure which one is the best for your car, don't worry, as KW Suspensions has got an optimal setup for Infiniti G37. Being the world's leading supplier of the best quality performance suspension parts, they've developed their newest V3 Inox-Line Lowering Coilover Kit to provide you with the maximum driving pleasure, better handling, and sleek look.
Apart from being manufactured to ideally replace your factory suspension components, KW Suspension V3 Inox coilovers can be manually adjusted to your driving style and personal preferences. They are durable, corrosion resistant, 100% street legal and German TUV approved. Will ideally perform either on the road or at a racetrack. V3 Inox-Line Lowering Coilover Kit is an easy way for you to experience the advanced performance and open the inner capabilities of your G37, see more details on this kit here:
KW Suspensions® - V3 Inox-Line Coilover Lowering Kit at CARiD
https://www.carid.com/images/kw-susp...s/35210051.jpg
https://www.carid.com/images/kw-susp...zed-dealer.jpg
Add an aggressive stanced look to your G37 and improve its handling at the same time with our selection of performance-oriented suspension components by KW SUspensions.
