Charlotte, NC - Help with Coilover Install
Like the title says, I need some assistance. I bought the Tein Street Basis Z coilovers and though I've done suspension work before, this is a bit more involved and on a different type of vehicle.
Wondering if anyone in Charlotte of close by would be willing to assist. I can provide pizza and/or wings and beer. Even willing to come to you if you have tools. My tool collection is not extensive, but I generally have enough. I have a small compressor but no air tools. I want to get this done, let them settle and get an alignment before I buy tires for my new wheels. All of this needs to be soon or I'll have to buy more factory size tires and I don't want to do that. Oh and if you've wrapped your window trim and want to help with that I'm there too:BOUNCE: |
I'd help, but I don't have a free weekend until mid June.
Good luck, install should be straight forward, but I say that having only done springs/shocks on my G. |
Yeah, I believe I have to use the factory tophats for the Street Basis. Maybe it's just the one bolt that is causing concern then... Thanks anyway Lego
I'm guessing your car is a dd? Do you have a spring compressor?
If the car is from OH, you might need air tools.. How big is your air compressor? If it's a southern car, then you should be ok without air. Where are you located? Even being in charlotte, you might be an hour+ from some of us. Also, I haven't done any suspension work on a G myself, so I'd only help as muscle, really. Better read up on multiple how-tos :D |
Originally Posted by kiseliok
(Post 4196177)
If the car is from OH, you might need air tools.. Car is from Texas. Had it shipped up here from there How big is your air compressor? 2 or 3 gallon If it's a southern car, then you should be ok without air. Southern car Where are you located? Even being in charlotte, you might be an hour+ from some of us. I'm at 49 and 485 - Not too far from Harrisburg. But willing to go to whomever knows how to help Also, I haven't done any suspension work on a G myself, so I'd only help as muscle, really. Better read up on multiple how-tos :D |
I'm not too far from you - 39 x 485.
How long can you go without the car? I've seen a lot of suspension installs (not specific to Gs) and they NEVER go as planned. A lot of times it takes 2+ days. |
(Post 4196721)
How long can you go without the car? I've seen a lot of suspension installs (not specific to Gs) and they NEVER go as planned. A lot of times it takes 2+ days. You'll need a spring compressor to disassemble the fronts to get the top hats. IDK about the Basis, but I didn't need a spring compressor to reassemble the Swifts with the shcoks :dunno: Rear is easy, no spring compressor needed. Getting the lower bolts off is the most difficult. But you can always use an box/open end wrench (6 point is best) and put a hydraulic jack under the open end and jack it up to break the bolt free. |
(Post 4196721)
Originally Posted by r2dmax
(Post 4197101)
I have my e46 if things really go bad
Originally Posted by Entcee
(Post 4197103)
Off topic, but I had an E46 before the G. What year is yours? Are you a member of E46fanatics?
Yeah, I thought I would stay with a Euro, but wanted something a little more reliable. Although, I loved my 2002 325i and it had 212k+ miles on it when I got rid of it. IMO the E46 is one of the more reliable BMWs.
This is my 1st. I've had 3 e30s: Coupe, saloon, vert
e39 Touring M Sport Manual e32 735iL e24 635cs Plus quite a few other euro brands |
(Post 4196165)
Good luck, install should be straight forward, but I say that having only done springs/shocks on my G. I got busy over the last month or so. I want this done and I hate paying labor for something I know I can do! |
