g37 vert: Service Engine Soon light
In my newly purchased used car, Service Engine light along with oil change sign comes on when I turn on it to level where electrical functions like music, light etc works and does not go away. But when I start the engine, both disappears.
Is this normal? or does it really need servicing since oil change light also comes on initially?
If that changes anything - I think next service is due in November month but it's still one month and it was not probably driven much since last service since it was on sale for some time before I bought it.
And to the op. Have autozone, napa, oreilly reset the ses for you rather than trying that tedious step. But unless you fixed the problem it'll just come back on.
I understand that all lights come on once and go off quickly in Accessory mode but in my case service engine and oil change remains on forever until engine is started. Is this still normal?
My service engine light was on, took it to the dealer thinking it might be nothing more than a gas cap issue. Turned out it was a crack in the catalytic converter, and they had to change the whole thing. cost $1200!, luckily it as covered under the warranty. So my suggestion take it and get the code and see if its anything running fine.
superjoey
31
03-22-2023 11:56 PM
