Aftermarket parts
There’s a few things I’m looking for to install over the winter. I am doing a “budget” build so I really am looking for good deals. Very used parts are welcomed.
Im located in Indiana. Can pay shipping and maybe pickup if you’re within an 8 hour distance. email : Carl@filmsbycarl.com phone : 260-602-2887 Suspension - SPL Bumpsteer Outer Tie Rods ($80) ✅ - F+R Sway Bar Kit RWD ($140) ✅ - Front Subframe Brace - SPL Front Endlinks ($0) ✅ - SPL Rear Endlinks ($0) ✅ - Rear Subframe Brace - Middle Brace - Fender Brace - SPL Traction Arms ($60) ✅ Engine - Oil Cooler ($150) - CF Engine Cover ✅ - 2.5” intakes ✅ - Poly Engine Mounts ($80) ✅ - Top Secret Plate ✅ Drivetrain - Poly Diff Bushings ✅ - Poly Subframe bushings/collars ($75)✅ - Z1 Diff Cover ($120) ✅ Transmission - Poly Transmission Mount ($100)✅ - CMAK V2 or V3 ($200) ✅ -Clutch Kit (capable of 400wtq)✅ - JK Trans with no grinds ($1000)✅ - Short Shifter($65) ✅ Misc - RWD G37 Metal Undershroud Skid Plate ($93) ✅ -CF Steering wheel with LED ($450) |
Intakes & poly diff bushings sourced. (For less than I budgeted!!!!) keep the deals coming pls
I bought this skid plate on Amazon and my mechanic said it's similar quality to the others. I used the oe hardware and rivnuts.
Kojem Engine Splash Shield Guard Compatible with 2007-2019 Infiniti G35 G37 Q40 Q60 & Nissan 370Z Silvery Aluminum Under Tray Cover Skid Plate |
F/R sway bar kit
Intakes Diff bushings Poly trans mount CMAK Clutch kit Jk trans Have all been sourced. Just looking for subframe collars, poly engine mounts, spl outer tie rods, and braces. |
SPL Outer tie rods, Z1 poly engine mounts, and Z1 subframe collars sourced!!! Within budget!
looking for some subframe and chassis braces now 😎 |
Originally Posted by sr20dehauler
(Post 4328782)
CF Engine cover sourced!!!! Well within budget. Who’s got some braces to sell? 🤠
Nismo juke Recaro skins, B&M Short shifter, Z1 Diff Cover and Top secret Engine Cover Plate sourced 🤝
someone sell me some bracing!! |
