Tanabe Sustec Pro Comfort-R Coilovers
6 Attachment(s)
If you have a 08-13 RWD coupe or sedan, are looking for a good looking drop that you can adjust, wanting a quality ride, and something that won't break the bank, then I've got the item for you!
**DOES NOT FIT AWD MODELS** Buy my Tanabe Sustec Pro Comfort-R Coilovers. I've had these for a year so they have about 12,000 miles on them. The good news is that I work from home and I still don't have sway bars, so you can have peace of mind that they haven't seen any abuse. These pass the wifey test and ride near stock. I was very satisfied with the ride quality on these. They don't squeak or make any noise and aren't stiff. You won't feel every single bump in the road with these. Here is some more info on these from Tanabe... Specs for this application: Rear Wheel Drive Only Spring Rates: 10k front and 9k rear G37 Coupe RWD: Min Lowering Front: 1/2" (Maximum Height) Max Lowering Front: 3 1/8" (Maximum Drop) Min Lowering Rear: 1/8" (Maximum Height) Max Lowering Rear: 1 1/2" (Maximum Drop) G37 Sedan RWD: Min Lowering Front: 1/4" (Maximum Height) Max Lowering Front: 2 3/4" (Maximum Drop) Min Lowering Rear: 1/4" (Maximum Height) Max Lowering Rear: 2 3/8" (Maximum Drop) If you purchase these brand new they must be assembled with the top hats, rubber boots and other parts from your stock suspension in order to install. I'm including everything you need except for your stock rubber seats that are currently on your car or your top hat gaskets. It's a simple direct install. I'm also including the installation manual and the adjustment wrenches. I'm asking $650.00 shipped or $600.00 picked up locally. I'm in Birmingham, AL. **DOES NOT FIT AWD MODELS** |
Hahaha! I am also searching for coilovers that pass the wifey test. Nice to know that I’m not alone. Unfortunately I have an X model. GLWS |
Sale pending
Good luck with the sale. I grew up in Birmingham, but moved to Houston 7 years ago. I miss the food :(
Sold please close thread
