FS Entire GTSPEC chassis enforcement line for Infiniti G37
Price: $1300
Part fits: 2010+ G37 Sedan, 2008-2009 G37 Coupe
SOLD
GTSPEC 08+ G37 6 Points Rear Subframe Reinforcement Brace. 5 pieces kit, consists of a reinforcement plate and two 3 points triangle braces and 2 subframe mounting bracket. Adding reinforcement to the rear subframe by connecting the rear subframe to the chassis.
$339 GTS-SUS-1350
2. GTSPEC Rear Lower Lateral Reinforcement Brace (M Shape) for 07+ G35/G37
SOLD
GTSPEC Rear Lateral Tie Brace (M Shape) for 07+ G35/G37. Goes along the same line as the rear sway bar. ONLY fits stock or selective aftermarket exhaust system.
$136 GTS-SUS-1349
3. GTSPEC Front 4 Point Ladder Brace for 370Z/G37/ 07+ G35 Sedan
SOLD
GTSPEC Front 4 Point Ladder Brace for 370Z/G37/ 07+ G35 Sedan. Will not fit G35/G37X.
$189 GTS-SUS-1348
4. GTSPEC Front 2 Points Subframe Reinforcement Brace - Infiniti G35/G37 (07+)
SOLD
GTSPEC Front 2 Point Subframe Reinforcement Brace. Reinforcing the front subframe.
$89 GTS-SUS-1347
5. GTSPEC Fender Reinforcement Brace - Infiniti G37 (2008+)
GTSPEC Fender Reinforcement Brace For 08+ Infiniti G37
SOLD
$224 GTS-SUS-1346
6. GTSPEC Front Subframe Tie Brace (L+R) - Infiniti G35/G37 (07+)
SOLD
GTSPEC front subframe tie brace for 07+ G35 and G37. Adding two extra braces (left and right) from the subframe to the chassis of the body. A similar brace exist on G35 (X) AWD. Direct bolt on, not modification required. NOTE: WILL NOT FIT G35/G37 (X) AWD.
$145 GTS-SUS-1332
7. GTSPEC Front Strut Brace - Infiniti G37 Coupe/Sedan V36 (07+)
SOLD
Aluminum Type-D front strut brace for 2007+ G35 Sedan/ G37 Coupe. Polish center shaft with laser cut print. Forged 7075 end points for added rigidity.
$189 GTS-SUS-1320
8. GTSPEC Rear Lower Tie Brace For 350Z/G35/G37
SOLD
GTSPEC rear lower tie brace for the Nissan 350Z and Infinity G35. Increase your subframe rigidity. Constructed of air craft grade 6061 aluminum with triple internal wall for maximum rigidity.
Note: Also clear 07+ G35(X)Sedan and G37
***WILL NOT WORK WITH VEHICLES OPTIONED WITH REAR ACTIVE STEERING***
$93 GTS-SUS-1087
LOCAL PICK UP ONLY
