MyG37
MyG37 (https://www.myg37.com/forums/)
-   Newbie Corner (https://www.myg37.com/forums/newbie-corner-337/)
-   -   Drivers door won't open (https://www.myg37.com/forums/newbie-corner/263969-drivers-door-wont-open.html)
2011G37 Dec 27, 2014 12:41 AM
I've had the car for 4 months and this is the fourth time (twice today) that my drivers door will not open, using either the inside or outside handle.
The three other doors work fine. The lock/unlock mechanism works, but there is no tension on the drivers door handles.
I've heard it has something to do with ice on the cable inside the door panel. My dealership told me not to wash the car when it's cold outside, which is a dumb answer considering it's close to or freezing from October to March.
I usually have to run the car and wait anywhere from 10 minutes to an hour before it will open.
Any TSB's on this or recommendations?
telcoman Dec 29, 2014 11:51 AM
1 Attachment(s)
Originally Posted by 2011G37 (Post 3858191)
...... or recommendations?
Yes! Do not wash your car in freezing weather. Water has a habit of turning to ice.
On the day I took this photo I did not wash my car.
Had no problem opening the doors. I did have a problem getting up the incline on my driveway with over 8" of un plowed snow
Attachment 141178
Telcoman
Greycat Jan 15, 2015 08:26 PM
G37 Sedan Door Freezing
I've had this problem for two years, as many others have. The issue is not with the door lock freezing, but with the door latch actuator assembly. The driver's door actuator is prone to developing condensation inside the sealed part of the unit, and the condensate turns to ice in our lovely winters. I was never able to find a TSB for this problem, but after sufficient complaints from me, the dealer replaced the actuator under warranty. There have been several mornings with temperatures around minus 30 degrees since then, and it seems like the problem has been solved. Since this is well-known defect, anyone with this problem whose G37 is out of warranty should push for a free actuator replacement.
zpieces Feb 17, 2015 01:15 PM
Thanks Greycat for that info. I am also experiencing this issue in my car now, but I am no longer under warranty (go figure). I brought my car in for the 60k service two days ago at the dealer where they washed and vacuumed the car, and ever since when the car is cold I can't CLOSE the drivers side door, and when the car has been running I can't OPEN the drivers side door I have to exit through the passengers seat over the center console, and I'm 6'4" (it's not pretty). I contacted the dealership and they said this has nothing to do with their service and they want $754 to replace the actuator. Total BS. Not to mention, last time I brought my car in for an oil change they washed it and water/condensation showed up in my right front headlamp, a fix which they charge at least $1000 for. It seems like they are intentionally f*cking with my car to squeeze more money out of me.
Tired of climbing out of the passenger side! Any ideas?
telcoman Feb 17, 2015 05:17 PM
Originally Posted by zpieces (Post 3876276)
Any ideas?
Yes!
I always have my vehicle washed at the dealer and have never experienced a problem.
Yesterday morning it was 4 degrees above zero when I left for work and 2 above zero when I arrived 50 miles later. I drive about three miles to the NJ Turnpike and before I enter I remove my jacket and drive in a short sleeve shirt with the heat blasting at 76 degrees. I may back it down a bit if the cabin starts to feel too warm but that heat in the cabin gets rid of any moisture in the doors and windows.
Try it!
Telcoman
bobbygamer Jan 5, 2022 06:07 PM
Solution
Sorry to necro this thread but I wanted to help had this happen to me for the second time today it was 32 yesterday and thought it would be fine to get a wash arrg I'm 6'3 and getting out the passenger side is not easy the solution is simple crank the heat to max set it to top vent aim it at the door you can really get it going by maxing both seat heaters you may want to wear shorts.
© 2026 MH Sub I, LLC dba Internet Brands
