MyG37
MyG37 (https://www.myg37.com/forums/)
-   Midwestern (https://www.myg37.com/forums/midwestern-37/)
-   -   May be a tall order, but I'll ask anyway... (https://www.myg37.com/forums/midwestern/235532-may-be-a-tall-order-but-ill-ask-anyway.html)
zinger11 May 11, 2012 11:00 AM
I am having an issue with my 2010 G37x sedan. The car cranks but will not start. After running diagnostics and checking continuity & voltage between wires to/from the fuel pump and other parts of the car, I've determined that either the IPDM is bad (as stated in the FSM troubleshooting section) or the ECM is bad. I was hoping to try to get my hands on another working IPDM and/or ECM to test in my car before I go out and spend $1,000+.
I know it's a tall order, but would anyone be willing to lend an IPDM and/or ECM from your G37x so I can see which part, if any, I will need to replace? I totally understand if not; I just wanted to take a chance here first. I am located in St. Louis, MO.
Thanks much!
zinger11
Tazicon May 11, 2012 11:09 AM
Its a 2010, isn't it under warranty?
zinger11 May 11, 2012 11:52 AM
It is not under warranty. I bought the car wrecked (salvage) and I'm fixing it up myself.
Black Betty May 11, 2012 12:45 PM
Good luck. Asking to use someone's working electrical component out of their running car is a tall order indeed. There's always the chance that you could fry it while testing your car and then they'd be screwed.
Have you tried finding the parts at a local salvage yard much cheaper than buying new ones?
zinger11 May 11, 2012 02:16 PM
Black Betty,
Thanks for the reply. Unfortunately, a lot of the salvage yards around here do not carry "newer" cars. With it being an Infiniti, aka a luxury brand, that doesn't help either.
I know I'm asking a lot, but I'm really not expecting anyone to help me out; thought I'd take a chance though. It has worked for me in the past. I have a '91 Stealth that was having similar problems as my G37x. I asked to borrow an ECM from someone on 3si.org. This guy came over, helped me install & test, & we found out that the problem was indeed the ECM. I repaired my ECM and I was good to go, and his car was not affected at all.
Again, I know what COULD happen if something were to go awry, but if someone did happen to have one available, say in a salvage car they weren't driving, I'd be happy to offer compensation for the chance to test it in my car.
Thanks,
zinger11
Black Betty May 11, 2012 02:19 PM
Well best of luck with that Kevin. I hope you get it diagnosed.
zinger11 May 11, 2012 02:23 PM
Thanks, Black Betty. Much Appreciated!
kurens May 14, 2012 08:08 PM
Originally Posted by zinger11 (Post 3445097)
Black Betty,
Thanks,
Kevin B
check car-parts.com
i also bought wrecked g37 and you would be suprised how many parts for 2010 infiniti you can find there.
zinger11 May 15, 2012 08:38 AM
Thanks for the tip, kurens! I will definitely check them out.
Regards,
zinger11
© 2026 MH Sub I, LLC dba Internet Brands
