TUNERZ STORE | Chadwick's Triple Play Car Care Products
The “old way” of soap & water washing, plus claying the car, then applying a protective wax or finish was at least 2-3 hours. Chadwick's Triple Play Car Care System can be easily done in 30-45 minutes with the results of a professional detailer. Triple Play has been formulated to soften & encapsulate the dirt in our tested & proven micro fibre towels so there is no risk of scratching. Soap & water is very abrasive & does damage to your finish every time you use it. Typical waxes are only topical in nature so they evaporate & leave oily greasy surfaces. Chadwick's Triple Play was formulated out of necessity. Neil noticed after his client’s cars were detailed; the use of soap & water dulled & stripped the finish he had applied after one or two washings. Water has chemicals & minerals, Soap has PH & alkalinity. The combination of the two were damaging to the paint & finish. Time was also a factor. The “old way” of soap & water washing, plus claying the car, then applying a protective wax or finish was at least 2-3 hours. Chadwick's Triple Play Car Care System can be easily done in 30-45 minutes with the results of a professional detailer. Triple Play has been formulated to soften & encapsulate the dirt in our tested & proven micro fibre towels so there is no risk of scratching. Soap & water is very abrasive & does damage to your finish every time you use it. Typical waxes are only topical in nature so they evaporate & leave oily greasy surfaces. Fingerprints disappear with Chadwick’s Triple Play acrylic high gloss finish. It bonds to the factory clear coat for that deep wet Showroom Shine It’s the only protection your car will ever need. Each time you use it another layer of protection bonds to itself & will not cloud or haze. 3 steps in one bottle, Chadwick’s Triple Play. It has taken three years to perfect. Chadwick’s Triple Play has been tested in real time & real conditions (South Florida’s sun, heat and humidity) on over $750,000,000 worth of cars. Chadwick’s Triple Play is the only product & system used on Lamborghini Palm Beach cars (new & used) since 2011. “I have washed more cars the “old” soap & water way than probably anyone can imagine in the last 45 years. I knew I had to change my ways & find a new approach to the antiquated method of typical car care. For my own, as well as my clients peace of mind, I had to develop & formulate a system so I could be 100% sure it was safe, effective & consistently worked to the highest professional standards”. Neil Chadwick, December 2009 https://www.tunerzstore.com/image/ca...it-600x600.jpg PM me for details! |
Thanks for the continued support!
Best deals everyday!
Thanks for the orders!
| All times are GMT -4. The time now is 07:14 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
