FS: Fog Light LED Bulbs! SMD and Hi-Power LED. Upgrade your lights!
Paul,
What is the difference between the 29.99 and 59.99 price. How much brighter are the 59.99. I don't want to blind people. Also, how hot do these get?
Thanks,
Chris
Thanks,
Chris
911turbo, we will have the output pictures shortly.
CRIDDA, these do not get nearly as hot as stock bulbs. The $30 are about half as bright as stock, $60 are about as bright as stock. These are mainly for the visual effect of the pure white light, not for light output. Thank you!
FYI DD and all members. I tried to install the fog Hi-Power LED in the 2008 G37S and it wont fit. The bulb is too fat. The SMD version will fit as it is skinny like the other LED bulb I had. Looks like I wasted a few bucks trying this
DD - Looks like you'll have to stop advertising the Hi-power LED for the G37 H1 version. I think the H11 for 2011 should be ok as its a bigger opening for the bulb.
Thank you for the information. We will get a G in immediately to verify this. You can certainly return the lights, information is available at www.diodedynamics.com/service thanks!
Thank you for the information. We will get a G in immediately to verify this. You can certainly return the lights, information is available at Diode Dynamics thanks!
